Originally Posted by Fr. Joe 07T100
With a friend, today I installed the racetech emulators, springs and the damping rods and preload adjusters from traxxion. It's stiff as hell. Was wondering if anyone else who did this type of mod experienced this. I noticed that the new springs are about an inch longer than the stock. One thing I didn't do was to add new fork oil - forgot to get new stuff. I was careful to keep the stuff that was already in the forks and put it back in. Not sure what weight it was. Might that contribute to the stiffness?
thanks.
I did this earlier this year, and yes it was much stiffer than before but that was part of the goal. It sounds like there's too much oil in the forks. Did you just use the same quantity fork oil you removed, or did you set the oil height spec'd in the instructions in the Traxxion kit? Since the new parts (damper, emulator, spring, spacer) are different than the originals, you probably will have too much oil in the forks if you used the same quantity. Did you set the static sag to spec after reassembly? I ended up with the preload set 4+ marks out on the adjusters and it was a huge improvement over stock - very little dive yet smooth over minor bumps. I initially had it at 3 turns out (as spec'd in the manual), but it was too stiff and not enough static sag. HTH,
Rob
