Jets - How do I determine which size? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 06-01-2008, 10:13 PM   #1 (permalink)
Favourite Bike: '07 Bonnie Black
gritkisser's Avatar
Other Motorcycle: '09 KLR650
Extra Motorcycle: '92 KZ1000P
I've recently removed the snorkle and performed a bafflectomy w/ a few drilled holes through the first 2 plates on my '07 Bonnie. How do I determine if I need to re-jet and if so, what size jets? I've pulled the plugs a couple of times since doing all this and they look fine to me. I'm fairly close to sealevel (< 100ft) if that matters.
Go Gators!
gritkisser is offline   Reply With Quote
Old 06-01-2008, 11:40 PM   #2 (permalink)
dledinger's Avatar
Go here and try Pat's jetting calculator. For my bike...it worked out to be pretty darn close.
http://www.dinqua.com/
dledinger is offline   Reply With Quote
Old 06-01-2008, 11:47 PM   #3 (permalink)
gritkisser's Avatar
That's cool! Thanks.
Go Gators!
Old 06-02-2008, 02:20 PM   #4 (permalink)
Looking up jetting in a book begs the question. How do you know if you are too lean or rich? I need to do this since I recently changed exhaust.
Running a dyno is probably the most direct method to check tuning. But what about a quick method we can do ourselves? The common answer I've found is to run the bike for a short distance with new plugs, kill the engine and look at the plugs. I'm pretty sure this is discussed on this forum, and a google search got me this page:
https://www.johnsmotorcycleparts.com...uning_tips.htm
"ride around at part throttle gently accelerating but keeping below ½ throttle. You want to stay on the low speed circuit as much as possible. After about one mile, pull in the clutch and kill the engine. Remove the sparkplugs. Look at the insulator from the tip down as far as you can see."
2005 Thruxton
2000 Speed Triple
whoa is offline   Reply With Quote
Old 06-02-2008, 03:39 PM   #5 (permalink)
If you leave the snorkel off go up 2 main jet sizes to 115, if you keep the snorkel in go up 1 size to 112(112.5). Back out the pilot jet screws to a total of 3 turns. Unless you dyno the bike you won't know for sure but this should be close enough considering you haven't made any major modifications. You also may be able to get by only going up 1 jet size even with the snorkel out, I would try that first and see how it runs.
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics), 130 main jets with stock ( NAGB ) needles.
BillT100 is offline   Reply With Quote
Old 06-02-2008, 06:41 PM   #6 (permalink)
gritkisser's Avatar
Thank you. Now, I'm off to find the thread explaining how to do this.
Go Gators!
Two different size jets HD_Softy Twins Technical Talk 9 07-15-2007 10:33 PM
Re-Jetting - What size jets? Brit26 Twins Technical Talk 16 12-07-2006 04:12 PM
What size jets should I use? TJRCARRILLO Club Cafe' 3 06-23-2006 01:19 AM
What size Jets!!! gm16sw Twins Talk 11 02-03-2006 04:09 PM
What Size Jets for NH Togas? Liontari Twins Talk 2 09-20-2005 12:39 PM
