06-01-2008, 06:02 PM
Grand Prix 500 Favourite Bike: 2007 T-100
Posts: 91 Other Motorcycle: 2001 BMW R1100rs
"slipping" and backfire
Hi all, thanks for the great site- today I was riding my 2007 Bonneville t-100- it was raining slightly and I noticed going up a small hill at regular speed that the engine seemed to be slipping every few hindred feet- then when I turned on my road it backfired- has never done this- and then when I stopped and reved the throttle it went up to 5k and erratically bounced around? Im not as technically able as Id like tobe but this seemed odd- it has only my 1700 miles on it so this was scary- thanks for any ideas- could it be the rain?
Ryan
06-01-2008, 07:34 PM
SuperSport Favourite Bike: Modified 2005 T100
Posts: 1,318 Other Motorcycle: 1994 CB750
by engine slipping do you mean feeling as though its hitting reserve, with erratic firing etc? If so id say spray yer coils with WD40 before any riding in the rain. Had similar issue and the WD40 cured it.
Every sunday is mad sunday.......
06-01-2008, 07:37 PM
SuperSport Favourite Bike: 1966 Bonnie
Posts: 1,255 Other Motorcycle: Malvern Star
Another 07 faulty pick-up coil??
Maybe I m just paranoid, but there is too many of these failing for Triumph to ignore the problem anymore.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
06-01-2008, 07:57 PM
yes
thanks for the reply- yeah I went out just now and rev'ed it in neutral to 2.5k rpm's each time it sends the indicator up to 5k and back quickly 2-3 times quickly could that be coils still? is there also a thread about these coils? I appreciate the advice on the wd-40 and will do so- thanks Ry
06-01-2008, 10:36 PM
Moto Grand Prix Favourite Bike: '03 T-100 & '08Tiger1050
Pull off your seat.
Disconnect the battery (negative lead first).
Disconnect the igniter (flat black thing just a little ways behind the battery with a large electrical connection with many contacts. Put a lot of dielectric grease (you can buy this at any auto parts store) on the connector and reconnect the igniter.
Reconnect the battery (negative lead last). Make sure the connections are tight.
Install the seat and go for a ride. If this doesn't cure the problem, call the dealer and make an appointment for service.
Larry
06-01-2008, 10:40 PM
Site Supporter Legend Favourite Bike: 904cc Bonnie w/magwheels
Posts: 11,815 Other Motorcycle: 2005 Yamaha FZ1
yep, Redbird has it right! +1 to what he said.
06-02-2008, 08:32 AM
thanks guys
I appreciate the collective knowledge and will give it a try this morning thanks so much
06-02-2008, 08:35 PM
thanks NOW WHAT WHY?? HAAA!!!
ok guys you helped put a smile on my face, I did as you said and it didnt work at first, I did it again and IT WORKED like a charm, now what was it and why did it work? haaa shoud I still get it in to the dealer and replace something under warranty while I have one? I cant thank you all enough!
06-02-2008, 11:24 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
You're getting the moisture out of the electrical connections, which is what was making it intermittent. If the problem goes away, you not only do not have to take it to the dealer, but you've gained valuable knowledge.
Marty
06-03-2008, 12:36 AM
thanks and yes
tonight I did feel great knowing I had fixed the problem and learned someting new- as you mentioned- I think as these things come up and I tackle them I will feel much more useful and connected
