05-31-2008, 09:52 PM
250 Grand Prix Favourite Bike: 2007 Thruxton
Bike Won't Start.
So I took the bike out for a ride today, probably about 2 hours, ran great, no problems whatsoever. I went to start it about 3 hours after the ride and it won't start (yes there is gas in it). I was looking around the carbs looking for a potential problem there when I noticed one of the electrical connections on the bottom of the left carb wasn't connected (the round on, not the flat one). So I reconnected thinking this would solve the problem but apparently not, the bike still won't start. I checked the spark plugs, the vacuum plugs, all the electrical connections and it seems to be fine. When I push the starter it makes the same noises it normally does when it starts, it just won't kick over. Anybody got any ideas? I'm stumped. and pissed. I really wanted to ride tomorrow......
 '07 Thrux fender eliminated, AI removal, CRG Bar ends, lowered gauges, relocated ignition, Chopped up Airbox, Bafflectomy, 132.5 mains 42 pilots, 2 &1/2 Turns....
05-31-2008, 10:03 PM
SuperSport Favourite Bike: 1966 Bonnie
Posts: 1,255 Other Motorcycle: Malvern Star
If its turning over its not a faulty sidestand switch.
* try opening the drain plugs in the float bowls to ensure there is fuel.
* remove a plug reconect it to the lead and ground it on the cylinder head and press the starter to see if it has spark.
These two tests should narrow down your problem.
There have been lots of cases of faulty pick up coils on 06/07 Twins so this may be your problem.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
05-31-2008, 10:06 PM
I'm on my way out to check the plugs now, I know the carbs are getting fuel I can hear it when I twist the throttle with the ignition switched pressed.....
05-31-2008, 10:09 PM
Loose Head Administrator
Site Supporter Supernova Favourite Bike: 2011 Tiger 800XC
Posts: 21,419 Other Motorcycle: 2007 Bonneville Big Carbs Extra Motorcycle: G12DL, ZX1100, KLR650
Your post says it won't kick over - so are you hearing clicking when you press the starter button, or is the motor actually turning over?
If it's not turning over - have you checked the kill switch (catches MANY people out).
If it's just clicking, not turning over, check ground connections, battery connections and starter relay connections.
05-31-2008, 11:53 PM
Moto Grand Prix Favourite Bike: '03 T-100 & '08Tiger1050
Step 1, IMHO: Determine if the spark plugs are firing.
I noticed you have relocated your ignition switch...might be worth a check to make sure the wires to the switch are OK and attached as they should be.
Larry
05-31-2008, 11:57 PM
Starting
Kill switch or side stand?? To fast & no symptoms to be anything real serious??
Good luck! Id be pissed as well. The only time my Bonne didnt start was some one accidently hit the kill switch! Puzzled the hell outa me till I figured what it was. I NEVER use the switch. It may have happenned when I let a friend reide it? I AWAYS check it now!!
CAPT D
06-01-2008, 12:06 AM
If its the kill switch or side stand switch you wont get any noises from the starter as the switches isolate the current to it.
I m not sure how BlackThrux can hear fuel getting to the carbs when he twists the throttle though ??
06-01-2008, 07:56 AM
SuperStock Favourite Bike: Velocette Thruxton
Posts: 220 Other Motorcycle: BMW R1100RS Extra Motorcycle: 67 BMW R60, with sidecar
What does that mean, it won't kick over? You said it makes the same noises it normally does.
So, when you press the starter button, is the motor turning over but it won't fire, or is the motor NOT turning over?
Loud pipes are rude and inconsiderate.
06-01-2008, 02:24 PM
I'm not getting spark. I checked both plugs, neither is firing. What do I do now?
06-01-2008, 02:27 PM
Motor is turning over but won't fire.
