270 vs 360 Crank configuration - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 05-30-2008, 10:33 AM Thread Starter
Main Motorcycle: Tiger
BarkSlayer's Avatar
Can somebody straighten me out here? I'm ready to buy a Scrambler and have noticed conflicting reports on whether the engine's crankshaft is configured at 270 degrees or at 360. Initially, I was under the impression that it was 270 degrees. Was there a change? If so, when?
Are there any real world benefits to either the 270 or 360 degree crankshaft? Is the difference noticeable while underway?
Is anyone aware of a web site that lists the chronology of the model, with changes noted from model year to model year?
I really miss my '99 Tiger and am hoping the Scrambler will fill bill for a back roads bike with some panache. Any help would be greatly appreciated.
BMW R1200RT • KTM 300XC-W
BarkSlayer is offline
post #2 of 12 (permalink) Old 05-30-2008, 11:07 AM
Pokeyjoe's Avatar
Its 270°. I think the Scrambler will fit your needs, but highly recommend dropping a tooth on the front sprocket. Stock is 18T. 17T is much, much better.
John
3-7-77
Pokeyjoe is offline
post #3 of 12 (permalink) Old 05-30-2008, 01:37 PM
Main Motorcycle: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a CR&S Vun
Try: http://www.totalmotorcycle.com/photo...ls-Triumph.htm
Greetings,
Thor
'04 T100 used to be B&W, now is Aluminium
904, 813, port&polish, Pieman igniter, rebuilt front (valves, springs, etc), Öhlins shocks, tubeless alu rims, JMC alu swingarm, DeCaesar alu triple trees, MASSmoto pipes, Ti nuts and bolts
- Ringer
TB-T100 is offline
post #4 of 12 (permalink) Old 05-30-2008, 03:15 PM
Pokeyjoe's Avatar
Originally Posted by TB-T100 View Post
That site says 360 in one spot and 270 in another. Its 270.
John
3-7-77
Pokeyjoe is offline
post #5 of 12 (permalink) Old 05-30-2008, 03:31 PM
Main Motorcycle: T120 '68
Rhodie's Avatar
Other Motorcycle: R1200GS
I believe the genesis of this error originated in a muddled press release
that was not properly proof-read.
It is still 270.
If these photos on the site were to be believed, it appears that the Scram's engine
has reverted back to its original "bare" non-black state.
However if you look at their e-brochure you will see the mill still coated in glorious black.
http://www.triumph.co.uk/Triumph_eBr...glish/book.htm
p46-47
The Dogs bark, but the Caravan moves on ... Eastern Proverb
Rhodie is offline
post #6 of 12 (permalink) Old 05-30-2008, 04:21 PM
Main Motorcycle: 07 Triumph Scrambler
justbrian's Avatar
Definitely a 270. I have test ridden the Bonneville and own a Scrambler. The 270 crank will benefit you in that it moves the peak of the torque curve lower into the rev range. The trade-off in this is loss of some top end horsepower. If you're moving mostly on back roads (or even city streets) rather than cruising the highway, you'll probably appreciate the characteristics of the Scrambler.
Simple mods such as after market exhausts and K&N filter made an appreciable difference above 60mph for me - prior to that I really felt I was "pushing" when riding at interstate speeds. Further, more complex mods including removal of the air box, made an appreciable difference over the entire speed range.
With those changes I really feel like I've got "the best of both worlds" - great torque from 0-60 and plenty of legs from 60-90+.
I've got 16, 17 and 19T counter sprockets on the way (in addition to the stock 18), so I can toy with gearing ratios and tune for purpose (as it's a five minute change). I'll probably end up keeping two and selling off the spares - whatever gets me the best coverage for both in-town/dirt and highway/touring use!
justbrian is offline
post #7 of 12 (permalink) Old 05-30-2008, 04:44 PM
Main Motorcycle: None at the moment
Other Motorcycle: '09 KLR/'09 TU 250X
Bark-
As stated previously it is 270 and I quite like it. It is a little less smooth than the 360 crank but delivers more torque sooner (as already stated) and feels a little more 'adventurous'. Some people hate it.
What I really wanted to address was the switch from the Tiger (I have had a 955) and there are some very real differences. Most notably, the triple in the Tiger is the nicest engine I have ever ridden and the parallel twin in either guise does not come close. To offset that the Scrambler is much more maneuverable at low speeds, I had a habit of dropping the Tiger when not moving...turn signals got to be expensive.
The Scrambler's stock suspension is unacceptable and should be upgraded for any sort of not perfectly paved riding. On your test ride drive it on a rough road surface and try standing on the pegs (don't try this on an unpaved surface) to see what I mean. However, with a decent set of variable rate springs and some rear shocks it is much more tractable but does not measure up to the more modern swing arm on the Tiger.
The Tiger has a much taller riding and erect riding position (at least for me) than the Scrambler.
I no longer have the Tiger but still ride the Scrambler a lot, mostly as a commuter though. For back roads I pretty much use my F650 as it has the benefit of the high stance of the Tiger with the maneuverability of the Scrambler. I will point out that the Scrambler motor is far superior to the F650 so I don't miss the Tiger (i just don't think about the triple very much).
Hope that helps,
Fred
No such thing as cold weather, just inappropriate clothing.
pigpen955 is offline
post #8 of 12 (permalink) Old 05-30-2008, 04:56 PM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
Originally Posted by pigpen955 View Post
Bark-
actually, the 270 crank should be smoother than the 360.
sweatmachine is offline
post #9 of 12 (permalink) Old 05-30-2008, 05:24 PM
Main Motorcycle: '06 Thruxton
neuroboy74's Avatar
Other Motorcycle: it has pedals.
heh heh. he said erect.
http://img177.imageshack.us/img177/2076/homestarqa6.gif
neuroboy74 is offline
post #10 of 12 (permalink) Old 05-30-2008, 07:26 PM
WetSparks's Avatar
Other Motorcycle: Triumph T90 (1963)
Extra Motorcycle: Trophy 1200
Lurking somewhere in the back of my brain is the recollection of reading a spec sheet, or the likes, from Triumph. In it, it said that the 270 degree crank was developed for the US market as it creates an engine sound more acceptable to the US market. Us in the UK get the 360 degree crank as we will buy anything
WetSparks is offline
05 Bonnie optimum Configuration DharmaLion Twins Technical Talk 9 01-20-2008 10:10 PM
Computer Configuration Shawn Biker Hang-Out 44 11-08-2007 12:27 AM
270 Crank vs 360 Crank - please explain NHScrambler Twins Talk 18 06-06-2006 05:42 PM
2000 rs crank wounlt crank KidThunder650 Sprint Forum 3 04-15-2006 06:16 PM
T'Bird Sport Configuration Hinckley Classic Triples 9 03-16-2004 05:21 PM
