Clutch Freeplay Adjustment & Takeup Point - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 05-25-2008, 01:09 PM Thread Starter
The Jerk's Avatar
Hey guys,
So I've been riding the Scrambler around and I didn't really notice it until after I read through the service manual, but as delivered my clutch lever had about a half-inch or more of freeplay which of course is way out of spec (should be 2-3mm).
With a half-inch+ of freeplay, the clutch take-up point was basically right off the grip which I really liked because it made for faster starts & quicker shifting. I didn't notice anything wrong with that because it felt like the clutch on my Tiger which also engages right off the grip (though with a proper 2-3mm of freeplay).
Problem is I'm quite sure that with that much freeplay, I was not fully releasing the clutch when pulling the lever back to the grip. That equals extra heat and wear, not good.
So I adjusted the freeplay using the adjuster at the lever. Got the proper freeplay and all is well, except now when releasing the clutch, the friction point/takeup point is all the way out near the end of the lever travel, which I don't like as much. I can get used to it but it's making for some more awkward slow riding as I don't have as much fine control over the clutch with my fingers extended almost all the way.
So my question is, can I make an adjustment at the bottom adjuster (near the clutch itself) so that I can maintain the appropriate freeplay up top but that the takeup point will be moved closer to the lever? If the answer is no I don't want to screw with it but if the answer is yes I'd be willing to play around with it a bit to get it right.
2007 Triumph Tiger 1050 ABS
2007 Triumph Scrambler
The Jerk is offline
post #2 of 11 (permalink) Old 05-25-2008, 01:12 PM
Pokeyjoe's Avatar
I had much the same problem. I used the lever reach adjustment (1-4 knob) to bring the handle closer to the grip. It helped a lot.
John
3-7-77
Pokeyjoe is offline
post #3 of 11 (permalink) Old 05-25-2008, 01:16 PM Thread Starter
The Jerk's Avatar
I'm already at number 4.
Unfortunately that doesn't really help with moving the takeup point of the clutch, just moves the lever itself.
To get the proper freeplay at the lever, I had to unscrew the lever adjuster quite a bit. I think I might do the total adjustment as per the service manual, i.e. screw the upper adjuster all the way in, make the adjustment at the lower adjuster to remove all but a small amount of freeplay, then dial the final spec in with the top adjuster.
The Jerk is offline
post #4 of 11 (permalink) Old 05-25-2008, 01:37 PM
That's the way to do it.
Marty
Baltobonneville is offline
post #5 of 11 (permalink) Old 05-25-2008, 06:07 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
you can run alittle more free play wont hurt a thing as long as clutch disingaues enough to let it down shift and go out of gear good .To little free play is what hurts most that can make clutch slip.
mikeinva is offline
post #6 of 11 (permalink) Old 05-25-2008, 07:01 PM Thread Starter
The Jerk's Avatar
Well I did the full adjust and the takeup point is better now, not all the way out to the end of the lever travel like it was. Kind of in between. I noticed right away I was able to have better control of the clutch so the adjustment brought it in a little bit. Feels good now, I'm happy
The Jerk is offline
post #7 of 11 (permalink) Old 05-25-2008, 08:00 PM
Send a message via AIM to CAPTDON
Exclamation Free Play
And Too much free play is what burns up clutches & trashes gearboxes!! Slippage & drag will do the same harm!
CAPT D
CAPTDON is offline
post #8 of 11 (permalink) Old 09-16-2011, 01:19 AM
Main Motorcycle: 1970 Tiger
T_Ho's Avatar
Can someone post pictures for this step by step clutch adjustment?
T_Ho is offline
post #9 of 11 (permalink) Old 09-16-2011, 01:32 AM
Forchetto's Avatar
Forchetto is offline
post #10 of 11 (permalink) Old 09-16-2011, 03:25 AM
Main Motorcycle: 2007 Bonneville T100
SeeMore's Avatar
But those directions don't apply to your 1970 Tiger if that is what you were looking for. Do you have a modern Triumph too?
Chris
2007 Triumph T100
1974 Norton Commando
1989 Honda GB500, 1984 Moto Guzzi V65SP
1984 Honda Ascot Cafe Racer
2003 Suzuki V-Strom
SeeMore is offline
Clutch Adjustment cmb13 Hinckley Classic Triples 5 11-12-2008 08:09 AM
Clutch adjustment? argie Classic, Vintage & Veteran 3 01-23-2008 03:59 PM
clutch lever freeplay dnyman Twins Technical Talk 6 11-07-2007 06:51 PM
Clutch adjustment johnsime Twins Technical Talk 4 10-07-2006 08:04 PM
clutch engagement point carlivar Hinckley Classic Triples 10 07-08-2004 02:52 AM
