Using Floor Jack to Lube Chain
Searched this and could not find answers but .... My son recently purchased a Speed Triple (Oh to be young and have money) and we were lookng to clean and lube chain. Pulled out the trusty lift and "Holy No Lower Frame" I could not figure out a way to lift S3 with the Arrow 3 in 1 Shorty Pipes. So not willing to give up easily, we started to look for alternatives. Placed floor jack under shock support (only frame member I could find) and with me holding bike- gently lifted. Low and Behold, it worked great. Wheel just barely off floor, very stable and the voila - clean and lube done. This got me thinking - always dangerous - so I tried with my T100. Placed jack under frame crossmember and using stand as pivot/brace, lifted bike easily. Very stable and much faster than bike lift for chain clean and lube.
Before I try this again (I clean and lube a lot), anyone else have experience/experiences with this method? What am I harming and what are possible problems? I wonder if the weight load is too much for the sidestand. I will continue to use lift for big tasks but may stick to this method for this simple task unless you guys can talk me out of it.
Red and Black T100 - AI removed, Snorkel removed, Uni Filter, Baffelectomy - 2 drilled, National Cycles F16 Screen, 120 Mains, 1 shim
