Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBanditMotorcycle.com
Old 05-19-2008   #1 (permalink)
Favorite Bike: 2005 Bonneville
Other Motorcycle: 2005 V-Strom 1000
Extra Motorcycle: 2003 Trophy 1200 (wife's)
Oil Leak - Bottom of Engine
Somewhere on the bottom of my '05 790cc, aft of the oil filter, is an oil leak. Well, more like an oil seep. Not enough to affect the oil level noticeably, but enough that it needs cleaning every couple of days. If I don't clean it, it pools enough to drip on the rear tire.
I thought it might be the filter, so I did an oil & filter change a couple weeks ago, but no effect on the leak. It's definitely not coming from the oil drain plug - front of the engine is dry on the bottom. I guess the wind stream spreads the oil around, it's just very hard to localize except it's behind the filter.
There's a wire running into the bottom of the crankcase immediately behind the filter. Is it possible that fitting is leaking? Anyone have any likely guesses for a leak in this area?
Thanks,
Jonathan
jstark47 is offline   Reply With Quote
Old 05-19-2008   #2 (permalink)
That wire is either the neutral switch or the oil pressure switch, I'm not sure which. You could try disconnecting it and checking how tight the switch is. I believe it takes a deep 14mm socket.
Marty
Old 05-20-2008   #3 (permalink)
Favorite Bike: The One I'm Ridin' !
mrt202's Avatar
Oil Leak
Most common leaks seem to be the neutral safety switch which you mentioned, and output shaft ( front sprocket ) seal.
mrt202 is offline   Reply With Quote
Old 05-20-2008   #4 (permalink)
Favorite Bike: Black 06 Thruxton
Other Motorcycle: Red 01 SV650S
FYI, the oil pressure sending unit is fitted between the carbs, on the oil supply line for the camshafts. Rear of the cylinder head, of course.
Tusitala - Mt Vaea
SHILOH is online now   Reply With Quote
Old 05-20-2008   #5 (permalink)
Favorite Bike: t100 bonneville
bass-33's Avatar
rear sprocket
Hi there i just took my bike back to the dealer for an oil leak which ended up being a leak round the sprocket then dripping down past the oil filter. It took 2 oil filter changes before they found it but now good as new. regards Kevin
bass-33 is offline   Reply With Quote
Old 05-20-2008   #6 (permalink)
Favorite Bike: 2008 Triumph Bonneville
OhioSpeedmaster's Avatar
Had a similar leak at the beginning of the year..took it dealer and it turned out to be the neutral switch...replaced under warranty....apparently they have some sort of ceramic housing that has a tendency to fail....
OhioSpeedmaster is offline   Reply With Quote
Old 05-20-2008   #7 (permalink)
Thumbs up Oil leak
Chain crap build-up under the sprocket cover melting down?? A thought? Gotta clean out that mess x2/ yr!! It will melt down & look like an oil leak if it gets too "built up"? Doesnt sound serious?
CAPT D
Old 05-21-2008   #8 (permalink)
Favorite Bike: 2008 Bonnie T100
bonza's Avatar
mine leaks from the neutral safety switch. not much just a couple of drips every now and then.
originally thought it was the oil filter can.
2008 Black and White T100 Bonnie. AI removed, Bafflectomy, Triumph saddle bags sometimes
"Dont you throw those bloody spears at me!", Michael Caine.. Zulu
bonza is offline   Reply With Quote
Old 05-21-2008   #9 (permalink)
Yeah, that's what I thought too. It wasn't, but no harm in changing the oil & filter a little before time. I wonder if tightening the switch helps, or if it needs replacing? Anybody know what the torque spec is for the neutral switch?
bottom end grunt sean_x Hinckley Classic Triples 29 08-08-2007 07:32 PM
oil leak from top of engine drips off of throttle body? stwanted Speed Triple Forum 0 06-14-2007 07:57 PM
small oil leak from clutch on engine Crogers Speed Triple Forum 2 05-11-2007 08:58 PM
bottom engine bolt question Classic, Vintage & Veteran 5 10-18-2004 04:23 PM
still have leak at chaincase cover and now airbox wet on bottom ??? shedds Modifications & Workshop Talk 31 10-27-2003 04:34 PM
