Old 05-19-2008   #1 (permalink)
Favorite Bike: 2007 Scrambler
Pokeyjoe's Avatar
Scrambler Key Relocation
I would like to relocate my ignition switch, but the bracket its mounted in appears to be welded to the left fork. Is it? Will it come off?
John
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 05-19-2008   #2 (permalink)
Favorite Bike: Scrambler
johnyC's Avatar
removing scrambler lock plate
John,
The plate comes off quite easily, it's only spot welded to the fork shroud:
I drilled the four welded areas to weaken them, then waggled and levered it a bit until it came away. Don't get too 'medieval' on it though, you can mangle the shroud as it's quite soft. You should be left with, at worst, a few dents or holes and the area where the plate was which will be bare metal. I just put tape over mine, but you could always paint it if you're fussy
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 05-19-2008   #3 (permalink)
Pokeyjoe's Avatar
Thank you, sir!
John
Old 05-19-2008   #4 (permalink)
oregonthruxton's Avatar
Take a look at this easy relocation mod, about half way down the page.
'04 Thruxton
oregonthruxton is offline   Reply With Quote
Key Relocation Kit oregonthruxton Twins Technical Talk 68 04-01-2008 11:04 AM
Key Relocation Bugsy-12GSRC Twins Technical Talk 7 07-05-2007 09:59 PM
ignition relocation.... kidkazi Twins Technical Talk 3 03-31-2007 10:01 AM
key relocation skeeterbarnes Twins Talk 2 07-05-2006 09:36 PM
Fuesbox Relocation Doyle Hinckley Classic Triples 8 04-10-2006 08:24 PM
