AdvanstarMotorcycleShowsBikeBanditMotorcycle.com
Old 05-17-2008   #1 (permalink)
Favorite Bike: 1966 Bonnie
amanger's Avatar
Another Broken Bonnie....Grrrrrrr
My 07 Bonnie 865 has started playing up similar to others.It has gone fine for 5000 km then about 600 km ago started playing up.
It has the normal mods. ie Staintunes,NARK 140/40/shim from new.
It has a intermitant fault and will sometimes go for up to 100km no problems.
It will only play up when warm and then will miss or stall and sometimes not start for 3 minutes.
So far I have;
Drained tank,replaced fuel
Cleaned filters in tank/carbs
Drained cleaned carbs
Checked vent hose
Checked vacum plugs
Replaced spark plugs
Checked all conections on coil and ignitor
I dont think it is fuel related because the symptoms are still there after doing all of the above.
It is not the sidestand switch because it will still crank over.
I think it is either a faulty ignitor or crank sensor.Is there a sure fire way to check these?
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
Old 05-17-2008   #2 (permalink)
Favorite Bike: hayabusa,07 t100 red /blk
Other Motorcycle: 1978 kz z1r
my 07 was doing about the same thing when new.bring it in. make the dealer replace the pick up coil .mines been 0ver 1000 miles since and holding good.theres a thread with the part # here somewhere.ps that 3 minutes until restart will get longer and longer before it really goes out .something about the resistince going out of wack .i didnt really pay attantion when he was explaining.
used to going very,very fast.now trying to enjoy the ride.
u wish u could ride is offline   Reply With Quote
Broken rear spoke at 8100 mi. on 06 Bonnie BonnyGuy Twins Technical Talk 16 05-08-2008 10:56 AM
Broken Spokes ? Oh not, how about broken Rims BorgCymru Tiger Chat 4 12-03-2007 06:37 PM
me and bonnie are broken Topher Twins Technical Talk 35 04-01-2007 04:55 PM
Alanis' Broken-Down Bonnie! sid_farkus Twins Talk 15 08-18-2006 10:30 AM
Warning Bonnie owners !! 5 Spokes Broken !!! Rexa Twins Technical Talk 22 08-03-2006 06:41 AM
