I have the Dominator Touring pipes and have done the airbox eliminator with a rejet and am very happy with the results. I also changed from a 17 tooth front sprocket to an 18 tooth to reduce the revs on the freeway. It has a smooth power characteristic from 2500 and is a lot of fun to ride on the twisty mountain rodes; the torque allows me to use the throttle with a little less use of the shifter to navigate the curves.
2002 Bonneville - Dominator Touring exhaust, Airbox Eliminator, AI, 42 pilot, 150 mains, 18T, Ohlin shocks, Works dual rate springs.
