Hi there just wondering if anyone can help me. I have C R racing carbs on my bonnie and for some reason i cant use the choke,. As soon as i turn it on the bike stalls. This as become a problem since the weather as got colder over here. does anyone else have this problem. regards Kevin
does it run without the choke maybe the bike is already too rich at idle and the choke makes it worse
Lean out idle and try the choke then
At least that will tell you if the idle mixture is the culprit
Cheers Mr Stalker
Cheers i,ll give that a try. i must admit it does smell a little rich when i pull up at the lights. I have to ask. Is your sign on just a coincidents or are you really stalking me, lol. thanks again for your input
