The airbox is a very good noise reducer. It also provides "static air" for the carbs to draw air from. It is a pretty good lower front part of the rear fender until it begins to crack from age. It is a good place to mount fuses, relays, etc. until the rubber mounting straps break. It is a good battery box.
However, it really robs the bike of POWER, IMHO. Mine runs better from idle to redline without the airbox. It starts better, idles better, and really pulls above 5500 rpm.  I haven't touched the carbs in 20000 miles except to check carb balance a couple of times--no adjustment needed. I get 50+ mpg, and I do not ride like a grown-up.
Larry
