Trident-Exhausts.comBikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 05-30-2008   #51 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
glad you got her right looks pretty good man.Now ride the dang bike and have some fun.
Old 05-30-2008   #52 (permalink)
webonnielad's Avatar
Drilling.
Hi Frank
I took the jenks route which improved my throttle response considerabley.
Having said that I haven't fitted my ark yet, I'm just using a bellmouth.
To be on the safe side I managed to find a second hand pair of CVK36s to cannibalise the slides from though.
They cost me a £100 from a breaker.
You could try some auto jumbles to see what you turn up.
Failing that if you live near enough (say within 70 or so miles) maybe we could meet up and I could drop mine out for you to try.
Jon (UK)
webonnielad is offline   Reply With Quote
Old 05-30-2008   #53 (permalink)
Favorite Bike: the Triumph I'm riding
oldroadie's Avatar
Other Motorcycle: 04 America
Extra Motorcycle: 01 Bonneville
It's good to read that you've sorted this out.
2001 Bonneville
2004 Bonneville America
oldroadie is offline   Reply With Quote
Carb needle shim/washer Rhinoe Hinckley Classic Triples 15 11-11-2006 01:38 PM
Alternative D-Shaped Carb Tool? Sid Twins Technical Talk 16 08-15-2006 10:17 PM
Carb Needle Question jimmyj900 Twins Technical Talk 5 07-25-2006 07:28 AM
'78 T140E--Changing Carb Needle--Help lrw54 Classic, Vintage & Veteran 5 07-21-2005 04:23 PM
Bouncy Tach Needle - Carb Sync??? jasmail Hinckley Classic Triples 20 12-08-2004 09:31 PM
