Old 05-16-2008   #21 (permalink)
Favorite Bike: the Triumph I'm riding
oldroadie's Avatar
Other Motorcycle: 04 America
Extra Motorcycle: 01 Bonneville
Originally Posted by FrankBlack View Post
What's the TPS, O.R.? Yeah, the uphill theorem did occur to me. I'm clutching at straws a bit. Will keep playing with this though as it's bugging me now. Anyone else have this problem?
It's the throttle position sensor that sits on the right side of the carbs, the connector is under the right side cover (mine was tucked under the frame rail at the top). It's meant to adjust the ignitor performance at lower rpm's and I wonder if this is what's causing your erratic behavior.
2001 Bonneville
2004 Bonneville America
oldroadie is offline   Reply With Quote
Old 05-17-2008   #22 (permalink)
Favorite Bike: Triumph Bonneville 2007
FrankBlack's Avatar
Thumbs up shortlist
I appreciate all your input folks. I now have a little list of things to try:
1. play around with shims, pilot mixture, pilot jet size and main jet size - DONE
2. Disconnect the TPS (Throttle Position Sensor) and look for changes - if problem clears, take the bike to the dealer and have them reset it (can we assume that TPS can be reset? I know the manual says not but I've read on some threads that the dealer can do it...)
3. shorten the diaphragm springs in the carbs or try softer springs
If I've missed anything let me know.
All the best.
Silver Bonneville 2007
Burgess style silencers/45 pilots/145 mains/Turns:0.75L&1.25R/50 mpg avrg/FARK/Latest DYNO
FrankBlack is offline   Reply With Quote
Old 05-17-2008   #23 (permalink)
Thanks Wolverine - any ideas on the somewhere else?
My other thought - if it isn't the springs - is that I notice that the angle of my carburettors is slightly higher at the rear (where they would normally join the airbox at stock). It may be around 5mm higher than stock when I refitted them with the carb brace after my ARK. I had wondered whether the floats and slides might be affected by this slightly increased angle. Floats are set at 17mm - both checked last week, but at a steeper carb angle I'm wondering whether this would have the effect of increasing the float height, thereby affecting the fuel level in the bowls, thus affecting low rev performance. Also wondering whether this tilt might create a little more resistance in the action of the slides.
Welcome to the wonderful world of carbs!
My bike's in for its 6k service as I type and they gave me one of the new plastic-badged, fake carb Bonnevilles as a loaner. It's quieter than the wind noise round my helmet but runs smoother than a virgin's thigh. After all my noise about 'authentic' and 'real' carbs etc, I'm thinking 'Lord, maybe the suffering involved just isn't worth it!'. Bring on the microchip...
Frank,
I am not trying to be a smart a.. but you just hit it...bring on the microchip...
I have spent over 2k & 16 dyno runs...it finally came to me....this engine is a hemi engine...being and old SS/AA hemi racer...#1 a hemi loves compression--9-1 wont cut it..( used to run the pistons .055 of the head..so when the rod strtched out..the piston would barely touch the head...presto! big time power..
EFI is the answer...then the turbocharger...If you don't go that way...the EFI is worth 8 lbs of Torque& 8hp...messing with jet's,etc..is a waste of time...a guys got to think...you see all the guys with different combinations...lets just say they run ok..BAM the weather changes--it get's hot..result the engine goes rich...that will not work...The way i think about all this is:you can NOT out run-Money-expercience -Passion- the end 'nuff said.
if you want to persue thi subject- i'll be glad to help you--
what we have here is the compression is d... low it doesn't really light up no matter what you do...to me it's about rideability...it really doesn't matter how much Mx power the bike is making..it's all about EXACTLY where all the power is...torque moves things...
well...this post is long..probably boring everyone..later....
see ya...
by the way---my email ad is a:kennys@bellsouth.net
Kenny is offline   Reply With Quote
Old 05-17-2008   #24 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
ahhh its not a hemi its a closed chamber motor with 4 valve head .hemi means round chamber.
frank if you un hook the tps all it will do is adv. timeing at idle .Above idle you wont even know its gone.Mine has been unhooked for a year now dont need it.
Old 05-18-2008   #25 (permalink)
FrankBlack's Avatar
Tps
Thanks Kenny.
Mike, doesn't the TPS ultimately affect fuel consumption? I know it's probably a perennial question, but how come stock carbs have it and aftermarket ones don't?
Anyway, I'll try this today and post later.
Old 05-18-2008   #26 (permalink)
FrankBlack's Avatar
shorter springs
Okay, tried unplugging the TPS and I honestly didn't notice any difference. Thought I imagined some low-range smoothness, but not sure. I'd be interested in the pros and cons of doing this though, if anyone wants to comment...
Well, I shortened the slide springs (using safety wire to bind 2-3 coils together) and it appears to have smoothed out the roughness! Can't quite believe it (that's why I'm saying 'appears'). I'm hoping someone out there will have a couple of those dynojet springs they can sell me and I'll install those instead. But for now the bike seems to pull much more steadily through the whole low-end rev range.
Many thanks to everyone who offered help.
Old 05-18-2008   #27 (permalink)
Favorite Bike: 2007 Mulberry SM
MackDaddy's Avatar
Other Motorcycle: http://tinyurl.com/3ayfq2
Frank,
I'm using Kawasaki ZZR900 carb vacuum springs p.n. 92081-1760
Slightly shorter & lighter than stock. Give'm a try! They seem to work well for me.
Jim
07 Mulberry SpeedMaster
My Little RAT
My Pics
Nology Coils/1K Ohm Wires/NGK Iridium/UNI & Norman Hyde VS/125-42/NB PMS @ 2.25/TBS Needles/Long TORS
MackDaddy is offline   Reply With Quote
Old 05-18-2008   #28 (permalink)
FrankBlack's Avatar
Originally Posted by MackDaddy View Post
Frank,
Jim
Thanks Jim - appreciated.
Old 05-18-2008   #29 (permalink)
BellaCorse's Avatar
You rock Mack! Speaking of springs, thanks for sending those other ones. Don't think they'll fit the carbs however.<g>
/Mike
BellaCorse is offline   Reply With Quote
Old 05-18-2008   #30 (permalink)
MackDaddy's Avatar
/Mike
Thanks again for the SUPER customer service Mike. Those higher rate springs were just what the doctor ordered. Bravo!
Jim
My Little RAT
My Pics
Carb needle shim/washer Rhinoe Hinckley Classic Triples 15 11-11-2006 01:38 PM
Alternative D-Shaped Carb Tool? Sid Twins Technical Talk 16 08-15-2006 10:17 PM
Carb Needle Question jimmyj900 Twins Technical Talk 5 07-25-2006 07:28 AM
'78 T140E--Changing Carb Needle--Help lrw54 Classic, Vintage & Veteran 5 07-21-2005 04:23 PM
Bouncy Tach Needle - Carb Sync??? jasmail Hinckley Classic Triples 20 12-08-2004 09:31 PM
