» Links |
05-13-2008
2nd gear peculiarities
my bonnie shifts pretty nicely most of the time - but if it grinds at all, it's usually as i shift from first to second - almost as if i don't have the clutch completely in - but i DO. "grinds" is too strong a word, actually - it just doesn't shift smoothly into 2nd sometimes - and not very often. also - if actually riding in second, there's a strange kind of very light grinding feeling that i can feel throughout the bike - it's not gears, though, i'm pretty sure. don't know what to make of this. i'm open to your thoughts. so far, none of this is really freaking me out. whatever it is, it doesn't seem major.
2001 Triumph Bonneville
mods:
BellaCorse Slip-on Teardrop Mufflers, Nology coil, Nark airbox removal kit and K&N pod filters. stock needles + 1 shim under each. 150 mains, 42 pilots, 3 turns out.
Supersport 600 Favorite Bike: hayabusa,07 t100 red /blk
Posts: 163 Other Motorcycle: 1978 kz z1r
lol your clutch probly needs adjustment from the first gear burnout attempts.if you have your cycle in first gear and pull in the clutch then hit the starter does it leasrch foward a bit? if in first gear with bike running ,clutch in if you give it throttle does bike want to take off some?
used to going very,very fast.now trying to enjoy the ride.
05-13-2008
lol - hey - i'm not abusive to the old girl - just testing the threshold, that's all.
i'll have to try what you suggested - i never start the bike in first - always in neutral w/ no clutch. i'll try those two tests and report back, if i can remember. thanks for the feedback.
mods:
05-13-2008
its all good !! if you cant ride your bike the way you like, theres no reason in having it !! ive killed several. and ride the rest hard .they can take alot .
05-13-2008
Shift Problems
1st of all- What year is your Bonne? 2nd- is your clutch adjusted properly? A dimes clearance when cold? There could be a# of reasons you are experiencing what you are.
The answer to the above would help a LOT if figuring whats up? Let us know!
CAPT D
05-13-2008
my bonneville is an april 2001 model, as per my signature. as to the dime's worth of clearance, i'm ashamed to admit that even though i've put about 3000 miles on my bike, i've never mucked with the clutch. i guess i'll hit the haynes and learn a little about it, hey?
thanks,
~m
mods:
05-14-2008
2nd
I think we did a thing on this in another thread. Should have a dime clearance in the freeplay on the lever. Your bike as mentioned had a clutch issue. Check em both & check back!
CAPT D
05-17-2008
told you guys i'd get back to you on this. i don't have either of these problems. no lurching forward, does not want to take off prematurely. i think it's just a clutch adjustment problem. i'm actually going to sober up and deal with this problem this morning. or this afternoon, as the case may be.
mods:
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| gear box |
lefty290962 |
The Rocket Science Forum |
1 |
08-24-2007 09:37 AM |
| gear box |
lefty290962 |
2 |
07-31-2007 10:48 PM |
| '02 955i / Wisconsin / Gear, gear, gear. |
wwpageiv |
Daytona Deliberations |
2 |
06-06-2007 11:24 PM |
| I want a 5th gear.. |
Lespaul |
Twins Technical Talk |
21 |
04-28-2007 09:50 AM |
| 3rd gear |
spicoli |
Triumph SuperSports |
5 |
10-06-2004 08:14 PM |
