Motorcycle.com
Old 05-13-2008   #1 (permalink)
shifting from neutral to first
quick question. is it normal for the bike to have a mini jerk forwards when shifting from n to first? its not that big to where I can't hold the bike back. I can't remember if it was always like that bike I was thinking it might just be that the tran is catching to the motor so it gives that smalll jerk. is this normal or do I have to adjust something? doesn't happen if I roll backwards first though.
kidkazi is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
Retired Legend
sweatmachine's Avatar
I'd say it's normal, but you might check the adjustment of your clutch cable.
alright alright alright
Bonnie cafefighter!
Old 05-13-2008   #3 (permalink)
Favorite Bike: my '05 Bonnie Black
neuroboy74's Avatar
Other Motorcycle: right, i wish. . .
doesn't happen to me. . .
http://img177.imageshack.us/img177/2076/homestarqa6.gif
neuroboy74 is offline   Reply With Quote
Old 05-13-2008   #4 (permalink)
Favorite Bike: 2001 Triumph Bonneville
I get a slight lurch forward too with a bit of a clunk sound. nothing where the bike is actually pulling away, but more just like the gears catching. I figured this is normal as I've seen other bikes do the same.
Chadderbox is offline   Reply With Quote
Old 05-13-2008   #5 (permalink)
Favorite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Extra Motorcycle: '62 AJS 650 Twin
Check your clutch adjustment it's a sign the clutch is slightly engaged, or are you pulling your clutch lever in far enough, either way the clutch should adjust out 1st gear jerk.
Ride on !
Tbirdnz is offline   Reply With Quote
Old 05-13-2008   #6 (permalink)
Thumbs up Jerk in 1st
Its normal- espec when cold! You can break the grip on the clutch when cold by revving the motor in neutral w/ the clutch held in & when it runs down - shift! Breaks the wet -cold bond on the clutch. It will always clunk a little unless you are moving a little. The norms of a wet clutch! Shouldnt clunk TOO bad tho. I keep my clutch adjusted @ a dimes clearance. When hot & streched- the cable will open up a bit. The dime works well!! Not to worry!
CAPT D
CAPTDON is online now   Reply With Quote
Old 05-13-2008   #7 (permalink)
I guess that's better describe. I just thought about it and I go nowhere when I hold in the clutch.
Shifting to Neutral NYBonnie Twins Technical Talk 23 10-01-2007 10:34 PM
Neutral to First.... twlynch Classic, Vintage & Veteran 17 01-12-2007 10:58 PM
shifting. neutral to 1st ditchrat69 Triumph SuperSports 12 04-14-2006 03:01 PM
Neutral chrisengiines Tiger Chat 8 03-31-2005 01:09 PM
Neutral Spooner Hinckley Classic Triples 2 09-29-2004 09:01 AM
