Motorcycle.com
Old 05-12-2008   #1 (permalink)
Favorite Bike: 2007 Bonneville T100
T100Vince's Avatar
Extra Motorcycle: 2007 Yamaha Warrior
Chain Lube - WOW
At the risk of sounding like a newbe, I tried a new chain lube today and what a difference. I had been using a generic lube, penetrant and water displacer -cleaning and spraying every 200 or so miles. Tonight my son brought home some Repsol Chain Lube. Drive train was noticably smoother with very little noise. Felt like a different bike. If my son had said "try this, it will make your bike smoother" I would have said "Yeah right" and ignored him.
BTW - I am not being paid but wanted to let others know that a quality lube makes all the difference - Sorry could not resist.
Red and Black T100 - AI removed, Snorkel removed, Uni Filter, Baffelectomy - 2 drilled, National Cycles F16 Screen, 120 Mains, 1 shim
T100Vince is offline   Reply With Quote
Old 05-12-2008   #2 (permalink)
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
It does indeed make a big difference - or can anyway. I was at my local kawasaki dealer the other day and I see they just started carrying scottoilers. Those things are great - expensive but they massively cut down on chain lube maintenance, and keep your chain very clean. Basically consists of an oil reservoir that meters out small amounts of oil directly onto your chain while riding.
I had one on my bike in the UK, and it ws great. I never had to clean the chain, but getting the flow set right is critical. Get it wrong and you have oil all over the place, up your back.........
Anyway. Keep an eye out for them. When I get one on my bonnie I will post a review and pics of installation.
If you go flying back through time, and you see somebody else flying forward into the future, it's probably best to avoid eye contact.
Old 05-13-2008   #3 (permalink)
Yes, WD40 is not chain lube. You can put some on a rag and use it to clean the chain, though.
If you put proper lube on it, you don't need to do it that often. I go about 1000 miles--of relatively clean riding--between cleanings/lubes.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 05-13-2008   #4 (permalink)
Question Chain
I use WD to clean & wax to lube. Been that way for 4 yrs now & workin fine! Love the wax!!! No sling off & lasts for 400 mi+! Ea to his (or her ) own tho?
CAPT D
Old 05-13-2008   #5 (permalink)
Favorite Bike: 1955 250 Benelli 6speed TT racer
SHRuuM's Avatar
Originally Posted by T100Vince View Post
Repsol Chain Lube.
and you got it where?
Mods:Predators/fork stabilizer/AI removed/Keihin CR-S carbs/RaceTech fork springs/Nology wires&coil/Iridium plugs/Traxxion emulators/LSL sliders & damper/Napolean mirrors/Monza fuel cap/19t front sprkt/flyscreen/Pazzo Levers/Ohlins 36PL shocks
SHRuuM is offline   Reply With Quote
Old 05-13-2008   #6 (permalink)
Winzer Corporation's Polylube 250 is what I use. It has great cling and is long lasting. A great product for certain. Google it to find a supplr near you. I get it from a local sales rep.
2004 Thruxton
Ikons
Epco Stainless
pkcoon is offline   Reply With Quote
Old 05-13-2008   #7 (permalink)
That's all very well, but if you do get any appreciable grime / dust build up, the combo of sticky chain lube and grit can make a very efficibient grinding paste. The O rings are supposed to stop that stuff getting inside the rollers, but it's a tough environment.
I like the use of a lighter oil (not WD40 - far too lite) as it keeps the chain clean. Problem is, you have to continuously apply it.
Right now I use PJ1, which certainly works, but I am getting that scottoiler on next month.
I had one on a ZX1100 in the UK - in 3 years I never had to adjust or clean the chain it worked so well, and wiping of the bit of flung oil from the rear wheel was easy, and in fact helped me keep the rear wheel clean.
Whatever lube you use - ride safe and free chaps!
Old 05-13-2008   #8 (permalink)
Favorite Bike: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
What kind of oil is recommended for the Scottoiler? I've been considering getting one for my Commando.Sprocket replacement is an expensive PIA on those things,so meticulous chain maintenance is a must.I replace the chain on that bike when it starts to show any amount of stretch at all,not including initial run-in.Anything that would extend the life of those chains,and cut down some on maintenance would be welcome.
As far as conventional chain spray lube for my Scrambler goes,I have been very happy with Bel-Ray Super Clean.It seems to penetrate well,stays on the chain,and doesn't attract dirt,even with as much off-roading as I do.
Cheers!
Bruce
"What're ya rebellin' against Johnny?"
"Well uh,gas prices mostly,but don't get me started"
-Kieth May
The advantage of a bad memory is that one enjoys several times the same good things for the first time. -Nietzsche
CommandoRdster is online now   Reply With Quote
Old 05-13-2008   #9 (permalink)
Well, this is where they get you of course - scottoil recommend their own brand of oil for the thing, and it's not cheap.
However, a can of chain lube isn't that cheap either, and the stuff scottoiler sells has a certain cling to it that seems to stop it just flinging off all over the place - although if you adjust the flow in the wrong direction it will do just that.
Well there it is. For the price of the scottoiler you can buy a great many cans of chain lube.
I just love a nice clean chain though.
Old 05-13-2008   #10 (permalink)
Thumbs up Chain
Havent adjusted it in over a year! Use WD to clean & wax to lube.It works for me &a couple friends. The lack of adjustment says all is well! Try it- youll like it?
CAPT D
chain lube,what do you use? AH-1 Speed Triple Forum 33 3 Weeks Ago 07:16 PM
Looking for oil...and maybe some chain Lube killian101 Twins Technical Talk 1 11-02-2007 12:35 PM
chain lube ricster Sprint Forum 39 03-16-2007 02:59 AM
To Lube the chain or not to Lube...that is the Question Clanrickarde Twins Talk 27 02-25-2006 08:37 AM
Chain Lube Silverado57 Twins Talk 19 02-17-2006 10:37 AM
