Paul - nice work on the bracket, and props on the ingenuity with the wiring setup and rolling up the speedo. The thought of rigging something up with an electric drill came to mind but when I caught how long it took you to roll it forward I decided better. I'm likewise meticulous for detail, so it'll drive me nuts for a bit until I rig something up!
After reading your post and doing a bit of research, I ordered a set of S3 risers/top clamps. (for the "aluminum" finish)
I ordered up one of these for a bracket:
It's supposed to fit anything with risers 3.5" on center, and a quick ruler check confirms the scrambler is at least darn close. I can drill out/slot the holes a bit if needed to tweak the fit. If for some reason this doesn't work out I'll probably be giving you a shout!
I've also got a 7"/shallower chrome headlight (ala Lucas style) on the way with some Tommaselli style brackets.
Here's a couple of rather dimly lit "before" shots, if anyone is interested:
Anyone figured out where to move the fugly regulator?
