I had the same problem and the solution is to re-route the throttle cable.With the shorter and lower m-bars the cable is forced into a bend which is to tight causing the cable to bind.
If you disconect the cables from the twist grip you can re-route through the outside of the triple tree to reduce the arc.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
