Old 05-05-2008   #1 (permalink)
Favorite Bike: '01 Bonnie
Jedhook28's Avatar
Help Removing D&D baffles
Hi folks,
I attempted to do a little surgery on my D&D's this weekend. Planned on cutting the stock paking back a bit and stuffing them with Silent Sport packing. Had a hell of a time getting the baffles out, in fact I gave up before I ruined something.
How the heck do you get them out without buggering up the end of the baffle ?
Any advice will be appreciated.
Thanks,
jed
Check out my bike:
http://img254.imageshack.us/img254/6258/dscf6702lc0.jpg
Jedhook28 is offline   Reply With Quote
Old 05-06-2008   #2 (permalink)
Jedhook28's Avatar
Anyone ????
Check out my bike:
Old 05-06-2008   #3 (permalink)
Favorite Bike: Triumph Bonuxton
DrewDesign007's Avatar
Other Motorcycle: N/A
Extra Motorcycle: N/A
I have D&D's too - curious as well.
Scored as a rocker!
75% rocker - 50% mod
DrewDesign007 is offline   Reply With Quote
Old 05-06-2008   #4 (permalink)
There's a number of different approaches.
My favorite, is to take a very small flat blade screwdriver and cover it with electrical tape. Then find a wee gap between the muffler and end-cone. insert the scredrive blade and twist ever so carefully, to pry the cap away from the mega-phone. The end-cap will start to seperate from the megaphone. do this a couple of places and you can then twist it out by hand.
another option is to insert a hammer handle inside the baffle and use it to pull the end cap out.
Maybe even a slide hammer or something to hook the baffle from the inside and pull.
I've 25,000 miles and 4 or 5 re-packs on mine now and the little screwdriver trick hasn't failed me or scratched anything yet
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 05-06-2008   #5 (permalink)
mine were tough to get out, but I did it via the careful screwdriver method.
Mr. Whatisit? That guy treats objects like women, man.
whatisit is offline   Reply With Quote
Old 05-06-2008   #6 (permalink)
Favorite Bike: '07 Bonnie Black
Sic Semper Tyrannis's Avatar
Other Motorcycle: '91 Yamaha XT600
Thanks for the post, cyncrzr. I just got my D&Ds this year. I'll have to remember this aproach.
See ya on the road, skag. -Goose
'07 Bonnie Black, D&D reverse cones, no AI, Unifoam airfilter, snorkel removed, 128 main, 42 pilot, down-turned m-bars, LSL rearsets.
Sic Semper Tyrannis is offline   Reply With Quote
Old 05-06-2008   #7 (permalink)
Jedhook28's Avatar
I can get the end cap off no problem, the baffle is stuffed in there something fierce. I guess i'll try using a hammer handle.
Check out my bike:
Old 05-07-2008   #8 (permalink)
To which part is the Baffle "Stuffed" ? Is it inside the end-cap ? or inside the megaphone.
If it's in the end-cap use a little penetrating lubricant to release it. If it's in the megaphone - grab it with a pair of vice-grips and twist
Cheers y'all, Cyn-
Members Album
Old 05-07-2008   #9 (permalink)
cobra935o's Avatar
When did you do your first repack? I have about 5000 miles on mine now, just wondering when others did theirs?
Thanks,
Nathan
cobra935o is offline   Reply With Quote
Old 05-07-2008   #10 (permalink)
I repack mine every 5,000 miles or thereabouts, you can hear it start to sound flat, and by then a good portion of the packing has burnt up
Cheers y'all, Cyn-
Members Album
removing baffles? firegreg52 Twins Technical Talk 5 10-14-2007 11:08 PM
Removing baffles from stock America R100Pilot Twins Technical Talk 16 12-28-2006 07:14 PM
Removing Rear Baffles Pictures ArmyBonnie Twins Talk 16 01-19-2006 07:50 AM
Baffled by baffles idahotb Modifications & Workshop Talk 7 04-01-2005 05:20 PM
baffles seumas Modifications & Workshop Talk 3 08-14-2004 08:28 PM
