Motorcycle.com
Old 05-01-2008   #1 (permalink)
Favorite Bike: 1970 Triumph TR6R
McBike's Avatar
Other Motorcycle: 2007 T100
Extra Motorcycle: 1969 Bonnie Basket
2007 T100 Owners Manual Clarification
I have a questions about 2 items in my owners manual.
1. It instructs you to remove the battery cable before changing
the headlight bulb.
2. It warns you not to run out of fuel because it could do damage
to the catalytic converter.
An input would be appreciated.
Thanks
Mike
The older I get, the faster I went.
McBike is offline   Reply With Quote
Old 05-01-2008   #2 (permalink)
Favorite Bike: 2007 Bonneville Black
Can't comment on the fuel issue, but the reason for the suggestion to disconnect the battery cable for a headlight bulb swap is because there is a jungle of wiring and connectors inside the headlight cowl.
smartin108 is offline   Reply With Quote
Old 05-01-2008   #3 (permalink)
Question Cat
They got them on Bonne's now?? Havent seen one yet. Where do they put it??
CAPT D
Old 05-01-2008   #4 (permalink)
McBike's Avatar
I guess that that means there are live wires in there, even with the ignition off.
Thanks
Mike
Old 05-01-2008   #5 (permalink)
Favorite Bike: TIger 1050
Other Motorcycle: None right now
Its typical liability stuff. All connectors are multi-plug w/ no exposed ends. The bulb can easily be changed w/o disconnecting battery. I'm sure some markets have cats. Triumph has only one manual version. There are always hot wires.
the headlight bulb.
Thanks
Mike
I was so much older then, I'm younger than that now.
fastbike is offline   Reply With Quote
Old 05-01-2008   #6 (permalink)
Favorite Bike: all of them
Other Motorcycle: Thruxton, spd Triple
Extra Motorcycle: T140, BSA B50
the cats are in the mufflers
you can see the "honeycomb" if you look into the inlet
drlapo is offline   Reply With Quote
Old 05-01-2008   #7 (permalink)
When did they start with catalytic converters in the US models?
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
owners manual Bullys Speed Triple Forum 3 05-04-2007 10:40 PM
Owners Manual clintd01 Twins Talk 5 12-13-2006 10:31 PM
2007 sprint owners!! chefjohn Sprint Forum 5 11-14-2006 11:34 PM
T100 Owners Manual in PDF Format Delirium Twins Talk 1 04-09-2006 06:19 AM
Where can I find a service manual and owners manual? YumaTR6R Classic, Vintage & Veteran 6 02-12-2005 03:02 AM
