Motorcycle.com
Old 04-30-2008   #1 (permalink)
Bonnie/Thrux top tree's different sizes
Howdy all,
I bought a Bonnie top tree with risers from my local dealer to swap out with my Thruxton Top tree because, well because I feel like it. I pulled off my Thrux tree and went to slide the Bonnie tree on and man are they different! The hole for the stem nut on my Bonnie tree is almost 1/8 inch farther forward from the stem hole on my Thrux trees.
Has anyone experienced this? My Thrux is a 2004 and these are new clamps from the dealer, did they make some slight alteration to the rake angle of the bike? I put the front wheel down to try and get the Bonnie trees on but they wont go without some serious hammer work, while my Thrux trees slide right on.
Any help is appreciated.
Jake
Jakemuay is offline   Reply With Quote
Old 04-30-2008   #2 (permalink)
There's a rake/trail difference between the two ...
Thrux - 27º/97mm
Bonnie - 28º/110mm
Bonafide is offline   Reply With Quote
Old 04-30-2008   #3 (permalink)
AH! That makes sense. Do I run the risk of damaging my forks by running the Bonnie top tree with the Thruxton's bottom? Looks like that LSL CEK kit is going to be kicking my wallet in the crotch sometime soon.
Old 04-30-2008   #4 (permalink)
Retired Legend
sweatmachine's Avatar
yeah, it doesn't fit. You'd have to get bonnie lower trees, and it will change the trail numbers, but not the rake. They have the same frame, after all.
The trees aren't raked, but the offset is different as you've noted. (distance from the center of the forks to the center of the nut).
alright alright alright
Bonnie cafefighter!
Old 05-01-2008   #5 (permalink)
Thanks sweat and bonafied. I even bought a D9 bracket for this whole setup. Bummer.
bonnie v. thrux neuroboy74 Twins Technical Talk 26 04-24-2008 11:47 AM
Tank Sizes (Bonnie/Scrambler) Texascat Twins Technical Talk 1 12-16-2007 06:20 AM
Bonnie and Thrux needles the same for 07 ?? Laika Twins Technical Talk 6 11-16-2007 10:04 PM
bird + thrux and a little bonnie. CCR Twins Talk 4 07-10-2007 11:05 PM
Put up pics of my standard bonnie/thrux/black bonnie mutation faffyface Twins Talk 12 08-09-2005 11:40 AM
