» Links |
04-30-2008
Production 125 Favorite Bike: 2005 Bonneville T-100
Back wheel spins while on Centre stand
Hello Everyone. My back wheel spins while my T-100 is on the centre stand. It's not is gear, don't worry! If I stop it with my foot - it stops, but will start spinning again when I remove my foot. I wonder, is my clutch slipping? I don't feel it slipping while I ride, or while stopped with the clutch in. Any insight would be great, thanks. Also, I've never adjusted my clutch, just the play on the lever. cpF
Site Supporter Retired Legend Favorite Bike: 904cc Bonnie w/magwheels
it's normal.
04-30-2008
Moto Grand Prix Favorite Bike: '06 T100
No... if you can stop the tire from spinning easily, you're fine.
Phil (road dog)
Click on the Image for Larger Picture
04-30-2008
It's perfectly normal... I don't know the technical explanation, but they all do it.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
04-30-2008
See that's why you guys are awesome!
Thanks for the answer. I've never had a bike with a centre stand and just don't know how things should work. Awesome. cpF
04-30-2008
SuperStock Favorite Bike: Triumph Thruxton
Posts: 229 Other Motorcycle: Kawasaki ZRX1200R
I think the reason why the wheel will turn is because the clutch plates are so close together and they are submerged in motor oil and there is some drag as one part of the clutch spins and the other does not. I don't think dry clutch Ducatis do the same thing.
vanson1200r:2007 Thruxton Red with white stripe. AI, Emgo's, 125's, Shim's, Polaris Bellmouth, K&N.
04-30-2008
Team Owner Favorite Bike: 2003 T100
Posts: 3,766 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: No more at present time
You will notice that once the bike is warmed up, and the oil thins out, the wheel won't tend to turn as fast, or at all, when on the center stand in neutral. Same reason the bike clunks the first time you put it in gear when it's cold.
Bob
04-30-2008
Originally Posted by ohiorider
You will notice that once the bike is warmed up, and the oil thins out, the wheel won't tend to turn as fast, or at all, when on the center stand in neutral. Same reason the bike clunks the first time you put it in gear when it's cold. Bob
actually no.
the cold first gear cluck is (clutch disengaged) plate friction and thick oil, (old kick start you had to do a kick with the clutch disengaged to break the plates loose)
but the rear wheel spin (clutch engaged in neutral) is there's some friction between the shafts and gear bearing surfaces and perfectly normal...it's like stirring a spoon in liquid drives the liquid crazy.
05-01-2008
I like these easy questions.
Want to know which oil to use?
Marty
05-01-2008
Formula Extreme Favorite Bike: '71 Norton Commando
Posts: 812 Other Motorcycle: '07 Scrambler Extra Motorcycle: '71 BSA Victor B50MX
Just use a frothy mixture of WD-40 and Pledge.
Cheers!
Bruce
