What Chadderbox said ...
... is correct, cheap, quick and solves the problem.
You cannot tighten the mirrors enough to stop them moving because the screw bottoms out before the mirror is tight enough.
Remove one of the mirrors, put the little springy washer in your pocket and go to a hardware store with a decent selection of stainless steel metric hardware. Buy two split-ring lockwashers that are the same size as the washer in your pocket. The inside diameter is important and should match. The replacement lockwasher is a standard size and should be substantially thicker than the original washer.
Reassemble, using the new washers in place of the old ones. Make sure that each washer sits around the small collar or shoulder; you'll see what I mean when you have it in front of you.
At this point, you should be able to tighten the mirrors enough that they won't move.
Marty
