BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 04-29-2008   #11 (permalink)
Get a spark tester tool from a local auto parts outfit. They look like a spark plug with a grounding lead.
In the morning see if you have spark. If no spark you have an electrical glitch... Coils, pickup or ignitor. If you have spark then you have a fuel supply issue. Try the old unscrew the tank cap trick and see if she goes.
That is step one.
If you have no spark and connections to everything looks good then go grab a hair dryer and take off the seat. Warm the igniter for 2 or 3 minutes then wait another 2 minutes or so for the heat to "soak in". Thats how I diagnosed my igniter issue with the same symptoms. If not the igniter, do the same thing with the coil. If not the coil tell the dealer to get you a pickup coil.
That is step 2
If it starts when warming a component then try the same thing the next morning. Once could be a fluke. 2 or 3 days running and you'll know for sure.
That is step 3
Step 4 is to convince your dealer that you know what your talking about so they don't waste a week trying to duplicate the problem in a nice warm shop... Step 4 is the toughest step.
Colin_In_Ottawa is offline   Reply With Quote
Old 04-29-2008   #12 (permalink)
Favorite Bike: '07 Black & Red T100
slowgator's Avatar
Other Motorcycle: '70 T120R Bonneville, '78
No Go At All Now
Came home this afternoon and disproved my own theory... now she won't start in the afternoons either. Tried all the suggestions (thanks!) and will try once more in the morning after leaving the bike uncovered overnight in case that is an issue. If she won't fire up I will have the dealer tow it in and fix it as it is still under warranty.
After researching on this forum, it seems like this is relatively common problem with the carbed Bonnies; perhaps EFI is not such a bad idea?
At any rate, I will post what the dealer finds to help anyone with a similar problem.
"Some people never go crazy. What truly horrible lives they must lead." - Charles Bukowski
slowgator is offline   Reply With Quote
Old 04-29-2008   #13 (permalink)
Favorite Bike: 2008 Bonnie T100
bonza's Avatar
must be some sort of timer device that blocks starting in the AM.
oops! see that it wont start in the afternoon now as well. there goes that theory.
over here you can get a pressure pack can of "start you bastard". might want to give that a go.
2008 Black and White T100 Bonnie. AI removed, Bafflectomy, Triumph saddle bags sometimes
"Dont you throw those bloody spears at me!", Michael Caine.. Zulu
bonza is offline   Reply With Quote
Old 04-29-2008   #14 (permalink)
Favorite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 89 Goldwing (PimpZilla)
Extra Motorcycle: can't afford another
OK, I am wondering if it could be a starting procedure problem. 70 degrees should be an easy start. Are you opening the throttle at all? If so you are leaning it even more than stock. I live in AZ (hot but much drier). Pull the choke, hit the button, no throttle and always fires in 2-3 revs. The only time I fiddle with the throttle is after stopping for fuel after hard, hot runs. I have to open about 1/4 throttle to let some air in.
Just a thought.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Bafflectomy, K&N air, Bellmouth,40/115, 1 shim, Naps, Mair Windscreen, GTS-60 Saddlebags, +1 risers
Derby Boy is offline   Reply With Quote
Old 04-30-2008   #15 (permalink)
Kirkus51's Avatar
Sounds like somethings getting wet to me. never had a problem starting with my Bonnie, but I live a dry climate. Sounds like a condensation problem to me, or a bad ground, like Scratch"s Scram.
Kirkus51 is offline   Reply With Quote
Old 04-30-2008   #16 (permalink)
Favorite Bike: The one I'm riding now.
gonzo'st100's Avatar
Other Motorcycle: Vespa 150 Scooter
Check battery terminals...
I would also check the battery terminals. If they are not tight, sometimes they will not give enough juice to start the bike.
Gonzo's T100
gonzo'st100 is offline   Reply With Quote
Old 04-30-2008   #17 (permalink)
slowgator's Avatar
Where Can I Buy This Stuff???
MAN! What a roller coaster ride. She fired up this morning after refusing to go last night! Ran in, put on my jacket, helmet, gloves, excited for the ride in to the dealer. Had her half-choked, sounded like she was dying, pushed choke in, she was ready to die, gave her some throttle, she died. And wouldn't fire back up. Now the battery is worn from trying to start so much.
Time to call the tow truck.
Bonza, I'll pay premium price for a can of that stuff!
Old 04-30-2008   #18 (permalink)
Favorite Bike: Mine...of course
Bottle_Fed's Avatar
Other Motorcycle: 'Zuki GS1100E
Change your spark plugs, it sounds like they are fouled.
Greg
2001 Black Bonneville 1200cc "High Tuned Son-of-a-Bitch!"
Bored, Stroked, and Injected!
Life always gets better after a few gears and a shot of nitrous....
Bottle_Fed is offline   Reply With Quote
Old 04-30-2008   #19 (permalink)
slowgator's Avatar
This Is What A Warranty Is For
Thanks Greg,
You may be right. But since the bike is still on warranty and I have a plan with the dealer that provides free towing, I will let them figure it out. They can fix the problem that may be fouling the plugs if that is the case.
Just curious, did you buy your Bonnie in Jax? If so, where?
Old 04-30-2008   #20 (permalink)
Bottle_Fed's Avatar
I bought it second hand from a girl that works with my wife. I'm not sure where she got it from. The only dealer here in Jax is Cycle Accessories West.
Greg
Tough morning on the Bonnie! sponger Twins Technical Talk 16 09-30-2007 02:10 PM
Afternoon ride mybluett Twins Talk 7 09-25-2006 06:09 PM
Rode it home this afternoon stmike Speed Triple Forum 6 05-14-2006 08:08 PM
Collected her this afternoon. robnobrakes Speed Triple Forum 9 09-04-2005 03:30 AM
Red S3 in Flossmoor IL Sat. afternoon Illinilee Speed Triple Forum 0 05-17-2004 11:32 AM
