The guy I talked to had to have his center stand welded and had to use a Scrambler side stand, which apparently necessitated altering the bend in the left side header!
I have the stock bars. I've been a bit hesitant to get wider bars just because I lane split pretty regularly and I don't want to be smacking mirrors left and right. However, I do have 3/4" risers and modre's lowsets.
The guy I talked to also had a pretty slick seat/fuel setup. He has a Russell "day long" solo seat up front with a 5 gallon "box-style" fuel cell in back. It extends his total range to about 320 miles! trumpycam, your fuel solution sounds pretty elegant. I've been thinking of having a custom seat pan fabricated in the style of BMW GS (non-Adventure) seats, with a removable raised pillion section under which sits a mounting surface for a case or fuel cell.
Sampson makes custom fuel cells to fit any dimensions:
http://www.sampson-sporttouring.com/...uel_cells.html
