Clogged petcock ? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario Tourism
Old 04-24-2008, 09:45 PM   #1 (permalink)
Favourite Bike: '01 Bonnie
Jedhook28's Avatar
Clogged petcock ?
As I left work tonight, I let the bike warm up for about 3 min. Left work and took the highway. Got off and came to a stop sign on a back road on the way home. As I left the stop sign the bike felt like it wanted to die as I blipped the throttle. Made it about ten feet and it died. Started back up and the engine just wanted to die. Could not start it from that point.
I was about 1000yds from my folks so I pushed it to their place and tried to start it until I just about killed the battery.
I checked the spark and I have spark, I assume then that it's a fuel problem. The fuel line is not pinched and I had a full tank.
Just wondering if anyone has had problems with a clogged petcock ?
Any other ideas are much appreciated.
I have tomorrow off so I will devote as much time as it takes to figure it out.
"The government cannot give to anyone, anything, that it first does not take from someone else"
Check out my bike: (new picture)
http://i41.tinypic.com/a2f6er.jpg
Jedhook28 is offline   Reply With Quote
Old 04-24-2008, 09:53 PM   #2 (permalink)
Favourite Bike: 2005 Bonneville T-100
Panthermark's Avatar
It happens......
Mark
Old 04-24-2008, 09:54 PM   #3 (permalink)
take off the gas cap and see if it runs...if so, the vent is plugged and the tank is vacuum locked.
modre is offline   Reply With Quote
Old 04-24-2008, 09:55 PM   #4 (permalink)
and - it's very easy to do - double check the snorkle make sure you didn't pick up something that's blocking air into the airbox (this is really quick to check).
schnabba is offline   Reply With Quote
Old 04-24-2008, 09:58 PM   #5 (permalink)
Jedhook28's Avatar
Running with a chopped airbox and K&N's.
I'll check the tank and probably empty it for good measure for sediment. Any advice on rinsing it out ?
Can I use hot H20 and make sure it's dry ?
Old 04-24-2008, 10:57 PM   #6 (permalink)
Question Clogged
Hey lets just hope it isnt the paint in the fuel tank they started using, & the ethanol doing its thing!! That concept has scared me since when I saw an 07 w/ paint inside the tank!
Mine is raw steel- a blessing now I guess?
CAPT D
Old 04-25-2008, 12:45 AM   #7 (permalink)
my 07 only has paint around the opening for the fuel - I used a flashlight and a mirror to check - the only stuff in the tank is overspray from them painting the filler neck... but it's a lot of overspray - and I think it dries up before it hits the inside surface - which is why it's not sticking there, and coming loose, clogging up my fuel tap screen.
at 220 miles on the clock, there was a good enough amount of sediment to prevent about 1" of fuel from going through the screen. Not sure what that relates to for gallons....
easy to fix - pull the tank, pull the tap, clean the tap (I took it apart, cleaned, and reassembled). flush the line out with carb cleaner - swish a little gasoline through the tank to rinse any loose sediment out. Reinstall the tap.
I checked it again at 1500 miles (installed a pingel fuel tap) - it was still very clean - so I think , in my case, it was the overspray drying before it hit the inside bottom surface of the tank, at which point, a few tanks of fuel were enough to wash it on down to the fuel tap. My honda isn't painted inside the fuel filler neck.... wonder why they do it?
Clogged Carbs? jason Hinckley Classic Triples 9 06-24-2008 02:56 AM
Clogged Air Filter 05+ Beach Sprint Forum 12 10-27-2006 02:16 AM
95 Daytona 1200...clogged jets? tbat770 Daytona Deliberations 3 08-02-2006 08:42 AM
Clogged Filter? Trumpets4Years Maintenance & Workshop Talk 15 04-21-2004 09:22 AM
Wot!? no petcock?? Maintenance & Workshop Talk 9 10-23-2002 10:39 PM
