all you drillers out there - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew BonnevilleOntario Tourism
Old 04-24-2008, 04:26 PM   #1 (permalink)
Favourite Bike: 2007 Goodwood Grn Bonnie
DrueP's Avatar
Other Motorcycle: 2005 Black Vespa GT
Ok so I did my initial bafflectomy, 2007 bonnie and I'm pleased with the results. Much more fun to drive through the Lincoln tunnel now. I'm not looking for huge sound but would like just a bit more. I am now poised to drill the first two baffle plates. I'm not planning on doing any mods in terms of performance for a while. Bike is all stock in that direction. Can fellow bafflectomers weigh in on how much they drilled while still retaining the stock jetting, conventional wisdom and anything they've noticed. Thanks!
Drue
DrueP is offline   Reply With Quote
Old 04-24-2008, 04:34 PM   #2 (permalink)
Favourite Bike: 2005 Green TBA
danf_florida's Avatar
Other Motorcycle: 2009 HD 883L (Wife's)
Extra Motorcycle: 2007 Buell Blast
IMO, you need a little back pressure to run stock stuff. Leave the last baffle.
2005 TBA, AI removed, debaffled pipes, added tach, leather saddle bags, backrest, and luggage rack, K&N Air Filter.
danf_florida is offline   Reply With Quote
Old 04-24-2008, 06:39 PM   #3 (permalink)
DrueP's Avatar
I plan on only drilling the two plates closest to the end of the pipes where I removed the baffle so I think I should be good.
Old 04-24-2008, 07:46 PM   #4 (permalink)
Favourite Bike: '07 Creamsickle
Flyingmerkel's Avatar
Other Motorcycle: '73 Moto Guzzi V7 Sport
I drilled a 3/4" hole in each rear baffle and am pleased with the sound, it now has the proper amount of "rumble" with no rejetting or cost. If you would like it louder, try two holes each. I have heard that you can drill the next baffle in as well without upsetting the jetting but I haven't tried it. If I did I might start with a 1/2" hole. Have fun!
Pepperoni Bros. Racing - SCTA Landspeed Record Holder 750 M-PG - 750 M-PF
Flyingmerkel is offline   Reply With Quote
Old 04-24-2008, 07:55 PM   #5 (permalink)
Kirkus51's Avatar
I punched out all my rear baffles with a drift and there was no noticeable difference in the performance, just sounded better. Now I'm running the Triumph performance pipes and there's real pick up performance wise. There is a bit of a "burble" when i back off but no biggie.: The carbs are untouched to the best of my knowledge. I'm a "let the dealer do it" kinda guy.
By the way, my dealer said as long as you're not running straight headers there's enough back pressure.
Kirkus51 is offline   Reply With Quote
Old 04-25-2008, 10:01 AM   #6 (permalink)
DrueP's Avatar
Great! I'm going to go buy a long drill bit today. Any recommendations on length for just going through the final two?
Old 04-25-2008, 10:22 AM   #7 (permalink)
Thumbs up Drill
I did 4 1/2" holes in the last 2 p;lates & left the 1st un touched. Sounds sweet & runs as good!! Dont let thebit get stuck in the can tho!!
CAPT D
Old 04-25-2008, 10:28 AM   #8 (permalink)
DrueP's Avatar
Good thing to keep in mind! Thanks. I will try and get a very long bit so even if it comes loose from the drill I will be able to still get it out.
Old 04-25-2008, 02:51 PM   #9 (permalink)
Bit
Got my extended one @ sears. $12 I think? Ground a flat spot in the shank to avoid slippage . It has done 4 Bonnes , 1 America & 1 HD. Worth the $12 I guess? Good luck. Be careful to keep the drill strait as not to drill thru the side of the can! Happenned to one friend! Do as many (= amount on both sides) as you feeel you need. 4 did it for me.
CAPT D
Old 04-25-2008, 08:27 PM   #10 (permalink)
Favourite Bike: hayabusa,07 t100 red /blk
Other Motorcycle: 1978 kz z1r
good topic boys!! will be drilling tonite!!
used to going very,very fast.now trying to enjoy the ride.
u wish u could ride is offline   Reply With Quote
