Motorcycle.comBikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
Old 04-26-2008   #11 (permalink)
Favorite Bike: 2007 Scrambler
Pokeyjoe's Avatar
Originally Posted by Rhodie View Post
The use of the OE caliper cannot just be put atop the disc as bleeding will not be easy with the valve on the underside.
I've actually bled brakes with the nipple on the bottom before. The solution is to bleed them before you mount them up. Its really not an issue. I have a vacuum bleeder, so that simplifies things, too.
John
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 05-09-2008   #12 (permalink)
Favorite Bike: T120 '68
Rhodie's Avatar
Other Motorcycle: R1200GS
Rear Caliper Bracket - Update
Just finished the prototype made out of steel mounting OE rear caliper.
Presently testing the braking characteristics in this configuration.
Nothing untoward so far.
Also, if the OE brakeline is long enough - it appears to be.
When satisfied will have the bracket milled from high-grade aluminium billet.
Will also look into aesthetic & functional design issues!
Now, no further need for centre stand protection - Hooray!!!
Just a word on the OE front disc.
Like many others it has warped.
Just changed to an EBC semi-floater and it works like a treat.
Especially with the Harrison Billet-6.
Highly recommended.
The Dogs bark, but the Caravan moves on ... Eastern Proverb
Rhodie is offline   Reply With Quote
Old 08-05-2008   #13 (permalink)
Favorite Bike: Scrambler
Lascarcapac's Avatar
Hi Rodhie,
I cannot see the image of your Scrambler bracket prototype....
Please let me(us) know if it will be possible to buy one in the near future !!!
Thanks!!!
Pascal
Highly recommended.
Lascarcapac is offline   Reply With Quote
Rear Brake Caliper Fridgehq T3 Sport / Touring Forum 5 04-09-2008 04:34 PM
Rear Caliper PhxMan Sprint Forum 3 01-31-2008 10:14 PM
rear caliper wombatrider Triumph SuperSports 1 09-14-2007 02:19 PM
Rear brake caliper Scrambler bung1 Modifications & Workshop Talk 4 09-04-2007 04:38 PM
rear caliper pork Sprint Forum 0 02-20-2007 09:15 AM
