Old 04-19-2008   #1 (permalink)
Favorite Bike: My Black Bonnie
triblackville's Avatar
Other Motorcycle: Trek 1.2 White
throttle getting stuck
So I am swapping out for some M bars and I am following the instructions on here and for some odd reason my throttle will not pull back to the original position after simulating acceleration.
Can anybody help me to get it to go back?
triblackville is offline   Reply With Quote
Old 04-19-2008   #2 (permalink)
Retired Legend
sweatmachine's Avatar
rotate the throttle on the bars, check to make sure the cables aren't bound up somewhere, you may have to adjust the angle of the bars or reroute the cables.
Old 04-19-2008   #3 (permalink)
Hey thanks sweat for the quick answer i will try changing the angle
i know they arent tangled because I made sure
Old 04-19-2008   #4 (permalink)
thanks sweat changing the angle worked.
what to use to attach the grip again?
Old 04-19-2008   #5 (permalink)
Retired Legend
I have used with great success:
windex
rubbing alcohol
listerine
brake cleaner
gasoline
I don't like lubricants, like wd40, because they don't stick on right away, they kinda slip for a while.
Old 04-19-2008   #6 (permalink)
Favorite Bike: 70's BSA/Triumph triple's
ridesouth's Avatar
Other Motorcycle: many in past...way past
Extra Motorcycle: I wish!
Throttle can bind at the bar end
Check other thing that got me when I changed bars -- The throttle assembly can be too far up on the bar and the grip end is bound by the bar end, if that makes sense. I just moved the throttle back off the bar a mm or two and it freed right up. Enjoy the bars!
Ridesouth
'07 Black-no ai, airbox mod w/K&N, tach, K&Q,Thrux gel & Corbin seats, TOR's, Ikon shocks/springs, 19/43 sprockets,Highlander bars, PIAA 510'S
"...let's fire it up and wind it out...come on baby drive south." John Hiatt - "Drive South"
ridesouth is offline   Reply With Quote
Old 04-19-2008   #7 (permalink)
Favorite Bike: 2005 Bonneville T-100
Panthermark's Avatar
Yeah....it happens when you change bars......just takes a little tweaking.
You'll know something is wrong when you have the bike in neutral, turn the bars, and the engine revs for no reason. Throttle cable....
Mark
Old 04-19-2008   #8 (permalink)
Favorite Bike: '07 Bonnie Black
Sic Semper Tyrannis's Avatar
Other Motorcycle: '91 Yamaha XT600
+1 on moving the throttle up off the very end of the bar. Mine did the same thing when I switched to mbars. That'll fix ya right up.
See ya on the road, skag. -Goose
'07 Bonnie Black, D&D reverse cones, no AI, Unifoam airfilter, snorkel removed, 128 main, 42 pilot, down-turned m-bars, LSL rearsets.
Sic Semper Tyrannis is offline   Reply With Quote
Stuck throttle alii1959 Sprint Forum 5 02-04-2008 11:06 PM
GAS CAP STUCK! joeknows Twins Technical Talk 15 05-25-2007 08:38 AM
Stuck Throttle jonkull Classic, Vintage & Veteran 11 12-13-2006 03:28 PM
Stuck in the middle sprinter900 RAT - United Kingdom 1 06-26-2006 01:51 PM
Help! Speedo stuck bridgestone175 Sprint Forum 7 02-27-2006 06:12 PM
