AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.com
Old 04-17-2008   #1 (permalink)
Favorite Bike: Triumph Thruxville :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Extra Motorcycle: TR1 Chop/Bobber
PING: Peeps who have changed carbs
How did removing the wires that go back to the ECU affect the bike ?
I'm drawing up a single carb conversion but wondered how the carb sensors will affect the brain.
Thanks
BorgCymru is offline   Reply With Quote
Old 04-17-2008   #2 (permalink)
Retired Legend
sweatmachine's Avatar
The only difference I noticed was the massive power gain from the new carbs.
Old 04-17-2008   #3 (permalink)
Favorite Bike: My Bonneville of course
I remember someone once posting that they ran their bike on a dyno with stock carbs with and without the TPS hooked up. They got 1 less HP with the TPS disconnected. I am thinking thats within the acceptable variation you might expect from run to run so it didn't concern me.
As far as throttle response, the CV's by design lag. Open the butterfly which increases vaccum which lifts the slide. With the smooth bores when you twist the throttle the cable is actually lifting the slide. I am not finished tweaking the jets but as is the throttle response is freaking amazing. I just can't stop whacking the throttle open to feel the instant burst of power.
Plus you get to yank more wires! Less is more!
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 04-17-2008   #4 (permalink)
bonnevillebilly's Avatar
Hee.Hee yeah I noticed that massive power gain too.
Jeff have you tried installing the accelerator pumps on your carbs yet?
I just installed them last night then took it for a quick ride.
I took her to work this morning also, I not sure yet but I'm thinking they
do help a little with that slight bog when you whack it open.
I installed the #50 nozzles. I have to ride her a bit more to see if
they really do help.
When you look through the throat of the carbs you can see they give
a good squirt of gas at the needle. I have then set at 1/4 to 3/4 throttle.
I might change it to start at 3/8 to 1/2 and cut out at 3/4.
I still have to ride her some more to figure out what feels best.
Edit:
I'm sorry BorgCymru
I forgot to say I have not noticed any side effect from not having the TPS connected.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 04-17-2008   #5 (permalink)
Retired Legend
no, I haven't tried them. I worked 8am-10pm the last 2 days so there was no time/energy left for carb tweaking.
I want to change my needle position first, but after that I may give the pumps a try.
Old 04-17-2008   #6 (permalink)
Thanks
Perhaps with a PSI "big air" carb??
http://www.psipowerinc.com/bigAirCarbs.htm
rodburner is online now   Reply With Quote
Old 04-18-2008   #7 (permalink)
Favorite Bike: 02 Bonneville
Other Motorcycle: 05 SV650S
Nice concept on those carbs, but in the snowmobile world those guys have a less than stellar reputation...
According to some of my aquaintances, PSI = Pretty ****ty Investment
ivar is offline   Reply With Quote
Old 04-18-2008   #8 (permalink)
Interesting.They seem to be all the rage in the Harley oriented magazines.?? I personally always thought that the Lake injector was a cool carb for a bike,but I never did try one.When I thought I needed more oomph,I just bought a bigger,4 cylinder bike.
Old 04-18-2008   #9 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
the tps wont do a thing but advance timing at idle will run the same after you get moveing.
Will not hurt a thing i did away with mine a year ago.
Old 04-18-2008   #10 (permalink)
Does anybody remember Lectron carbs ?
Varna2Win is offline   Reply With Quote
Ping Meanchuck wiayeman T3 Sport / Touring Forum 4 03-28-2008 04:12 PM
Tire Rating Question for my peeps dblhelx Speed Triple Forum 7 09-28-2007 12:59 AM
Biker Peeps wenzel850 Biker Hang-Out 7 05-28-2007 10:43 AM
Ping Sweetmachine... 2112 Twins Technical Talk 11 04-15-2007 06:20 PM
Ping rino bradtx Daytona Deliberations 2 10-08-2006 05:15 AM
