Motorcycle.com
Old 04-19-2008   #21 (permalink)
Favorite Bike: 2007 T-100 Bonneville
seeing as how you live in a town that's about 80ft above sea level, it probably needed to be more rich.
I have to set mine - stock setup - around 3.25 turns out, otherwise it's hard to start, runs lean. Raleigh is a whopping 300ft above sea level. Now, if I lived at a higher elevation, things would certainly be different.
schnabba is offline   Reply With Quote
Old 04-25-2008   #22 (permalink)
Favorite Bike: '07 Black & Red T100
slowgator's Avatar
Other Motorcycle: '70 T120R Bonneville, '78
Now It Won't Start At All
Originally Posted by slowgator View Post
My 07 T100 usually starts first touch on the starter button BUT I SOMETIMES have a problem re-starting after stopping for gas or shutting down and parking for a few minutes.
Any ideas?
Went to get on the T100 this morning and it would not start; only cranked. Tried full choke, no choke and everything in-between. Had it in a month ago for the 12 month service and they may have adjusted the carbs as I told them it was stalling at low RPMs and hard-starting when warm as stated above.
Tried several times until the battery started to wear down but no luck. Any hints or help in getting her to fire up? Just turned over 5K on the clock.
"Some people never go crazy. What truly horrible lives they must lead." - Charles Bukowski
slowgator is offline   Reply With Quote
Old 04-25-2008   #23 (permalink)
Favorite Bike: Bonneville 750cc T140V
Other Motorcycle: Hinkley fake Bonnie T100
Go back to who 'serviced it' and get your money refunded, then find somebody who knows what they're doing.
English_Spanner is offline   Reply With Quote
Old 05-13-2008   #24 (permalink)
Newbie
Favorite Bike: 07 T-100
Other Motorcycle: 74 Commando
hard starting Bonneville
I picked my 07 T-100 up on Feb.14 and it was very cold here in Illinois U.S.It has started great from day one.
robert yancey is offline   Reply With Quote
Old 05-13-2008   #25 (permalink)
Kirkus51's Avatar
My Bonnie has always been pretty good starting up. I did have a problem when it was minus something outside and it did take a while to fire up then.
I'm with ACE. ride it enough to get new fuel in it.
Kirkus51 is offline   Reply With Quote
Old 05-13-2008   #26 (permalink)
Favorite Bike: Bonnie
Fix
I had the same problem all last riding season. Over the winter I had the AI removed and TORs added, starts now first time with choke even at 5C, the shop did something under warranty to do with the something gap, I can't read the document... will ask and post
bill rad is offline   Reply With Quote
Old 05-14-2008   #27 (permalink)
slowgator's Avatar
Update
Just an update. After having the T100 towed in to the dealer, of course the dealer could not duplicate the problem and she fired up every time for them. Even had them keep her overnight to try in the morning. No problem.
BUT they DID find a questionable electrical connection under the seat where they had installed the panniers and apparently the pannier harness was rubbing the connector, maybe shorting it out from time to time, causing the problem. They re-routed the wire over the harness and wanted to charge me $150 for the labor. I said how about the warranty. They said because the panniers were an accessory, it was only covered 30 days and I had THEM install them a year ago when the bike was new. I told them I didn't think it was right and talked with the service manager who offered to split the bill with me. I bit, but walked out a little sideways.
No problem since.
Old 05-14-2008   #28 (permalink)
Favorite Bike: Any Triumph Motorcycle
Gob-ny-geay's Avatar
Glad to hear you got the problem resolved... we hope.
I'd be on the phone to USA Triumph in Atlanta about the warranty issue. Get your money back. These guys installed the panniers as you stated, so they are responsible for the alleged wiring fault. I would also be interested in what that particular connector was, and what it has to do with the starting performance. Have them explain it to you clearly, if they can.
Experience has taught me that when mechanics start acting like these guys have been, they're guessing... at your expense!
Bob
"If you're not part of the solution, you're part of the problem".
Gob-ny-geay is offline   Reply With Quote
Old 05-14-2008   #29 (permalink)
slowgator's Avatar
E-Mail Addy for USA Triumph?
Anyone have an email addy for USA Triumph?
Old 05-14-2008   #30 (permalink)
Triumph Motorcycles (America) Ltd.
385 Walt Sanders Memorial Drive
Suite 100
Newnan, Georgia 30265
Main Telephone: (678) 854-2010
Ask for Peter Carleo
Bob
Hard starting VTXED Modifications & Workshop Talk 3 09-30-2007 03:01 PM
Hard starting / starting fluid TailHooker Hinckley Classic Triples 20 09-01-2007 12:39 PM
Hard Starting '04 RS troy520 Sprint Forum 9 02-04-2007 11:04 AM
Bonneville T100 cold weather hard starting Hogdad Twins Technical Talk 7 10-22-2006 04:34 PM
Hard starting ST unummyu Sprint Forum 20 08-12-2004 06:30 PM
