NARK CARB Question
After I installed the NARK I noticed that the carbs jiggle a bit even though I have the carb brace on.
Should the carb brace stop the carbs from moving all together and not even let it jiggle?
I ask this because it is moving quite a bit and right after I put on the NARK I have been having intermittent cut off problems and the carbs are jiggling way too much.
I am wondering if something is happening to the carb bowls with all that movement.
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
