Noisy takeoff
If I gouge the clutch and pile on the power like trying to induce wheelspin in a car, when I pull away on my T100, I can get a clatter from somewhere down below. I don't think it's the chain and would suspect summat like weak springs in the clutch, but I got a local mechanic to check it and he said 'I can see what you mean, but I wouldn't worry about it!' He didn't think it was clutch springs.
I can easily avoid it with a smoother, less aggressive takeoff and I can turn it on and off on the throttle when it happens, so it's not a problem, but I'm curious. Has anyone else experienced this?
The bike still only has about 3K on it and is running very well generally with no knocking or clutch slip &c. - is it something someone's had and which went away with time, as the mechanic suggested it might?
