» Log in
User Name Not a member yet?
Register Now!
  #41 (permalink)
Old 5 Days Ago
M-bar dimensions/installation? Recommendations?
Forgive a newbie question. I'm finding that I'd like something just a bit narrower and more pulled-back than the stock bars on my '05 Bonneville. There are stiff joints and age issues, so I don't want to push myself into something too extreme, but I'm wondering if the M-bars would give me what I'm looking for. I really like the look of the Ace bars, but suspect that this old carcass - which, short legs and all, really needed Modre's peg-lowering kit - might find that a bit uncomfortable over the long haul.
So: can someone give the basic specs/dimensions of the M-bars so I can compare those to stock? (And, well, what would the Ace bars do to the ergonomics of the rest of the body, while we're at it?)
And how big a hassle would the switch be? I am loathe to mess with clutch cables and brake lines any more than absolutely necessary, since everything works just great right now.
Just got the old bicycle out from winter storage, and noticed how much more comfortable I found those bars, which are considerably narrower in span than the stock bars on the Bonnie..
Thanks all,
Owen
  #42 (permalink)
Old 4 Days Ago
Mattrat's Avatar
Favorite Bike: '06 Bonneville Black
Send a message via AIM to Mattrat
bar switch is very easy. 15-20 minutes, most of which is getting the left grip off.
2006 Bonneville Black - Lots O' Black
best mod - Hedge's 8-ball choke...email him if you want one!
  #43 (permalink)
Old 3 Days Ago
Loxpump's Avatar
Send a message via AIM to Loxpump Send a message via Yahoo to Loxpump
Looking at picture after picture and was wondering. Is there a huge difference in the M bars and Superbars? Mainly the overall rise and pullback.
"Keep the government poor and remain free"
Semper Fi!
  #44 (permalink)
Old 2 Days Ago
As someone who's never changed out bars, I'll bite....why is just the left grip hard to get off??
"I spent a lot of my money on booze, birds, and fast cars. The rest I just squandered."
-George Best
  #45 (permalink)
Old 2 Days Ago
its glued to the bars. Just pry it up a bit with a small screwdriver and spray some WD40 or a blast of air under it and twist away.
Jer
2006 T100 Tangerine
1984 BMW R100RS
1972 NORTON COMBAT COMMANDO
1966 R60/2
  #46 (permalink)
Old 2 Days Ago
I'm inferring here that the actual switch procedure is a lot simpler than the description in the Haynes manual for removing handlebars????
That was a bit daunting to someone who'd never done it before, and involved taking apart the entire starter-button/brake-lever/throttle assemblage and such.
But am I right that you're implying that the entire throttle, brake, switch assembly can just be slid off the end of the bar and slid back onto the new one in one piece (assuming, of course, a reasonable loosening of the clamp screwss???
I've only ever removed rubber grips which were worn out and just cut 'em to bits, but I'd really like to preserve the ones I have. I guess I'd try the WD-40 trick. I also read somewhere than they can be nudged a bit with compressed air, too.
Anyway, am I right about that?
owen
  #47 (permalink)
Old 2 Days Ago
Favorite Bike: Triumph Bonnevile
Other Motorcycle: None
Extra Motorcycle: None
handlebar switch
Yes you can just loosen the throttle side and slide it off. You can also use soap and water to take the left grip off. Put some powder/liquid type soap in a container and put the bar in there for a while and it will come right off, the other type of removal works but this is less messy, air is also good. FWIW.
  #48 (permalink)
Old 5 Hours Ago
Favorite Bike: Triumph Bonneville Black
I just put m bars on last night and all I did was pull the grip back a little and squirted a little hand sanitizer in there and it slid right off. Seemed to break the glue down pretty fast. I did rinse the grip off right away as I wasn't sure if it would eat at the rubber at all.
  #49 (permalink)
Old 5 Hours Ago
Speaking of getting grips to come off what do you guys use to stick em back on?
Bonneville picture thread Jedhook28 Triumph Twins HangOut 806 6 Hours Ago 09:28 AM
Bonneville to Scrambler handlebar swap - not possible? Dale_K Twins Technical Talk 43 4 Weeks Ago 11:00 PM
Bonneville Picture Thread newbonne Twins Technical Talk 1 07-10-2007 09:27 PM
Bonneville Handlebar specs Benthicmerc Modifications & Workshop Talk 1 07-05-2007 01:27 PM
Bonneville Stock Handlebar Wall Thickness??? road_dog Twins Technical Talk 4 10-15-2006 07:08 PM
