Originally Posted by CYNCRZR
You'll probably need 2. Both need to read "NM - Newton Metres". Sears Craftsman, a 3/8" drive for the 9nm, and a 1/2 for the 60nm.
The Sears unit I use most covers 10 to 75 ft/lbs and is also graduated in nm 15 to 100 I think. It's 3/8 drive, about 50 dollars I think and while it won't do some of the light items, such as the cam caps, it covers most things.
I just use a 3/8 to 1/2 adapter for the wheel nut and bolts instead of a different wrench when I need 24 mm sockets and 60 nm. and then for the light stuff I have a 1/4 drive Sears or Parks unit for the (9nm type stuff, cam caps, etc).
I went the other way I guess from CYNCzr. Both work, and Sears stuff is good.
