When she's really cold ....
You might also try pulling the left side cover, and blocking the air intake (either the snorkle or the bellmouth if installed), and crank her over for a couple of seconds. If your problem is lack of enough fuel from the enrichener, this should pull a little extra fuel into the intake tracts.
There is no lack of suggestions for ways to start a stubborn Bonnie. Search this site for 'hard starting', for example, and you should come up with more suggestions than you'll ever have time to try.
Bob
