Neutral indicator light - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New BonnevilleOntario TourismMotorcycle.com
Old 04-03-2008, 05:50 PM   #1 (permalink)
Favourite Bike: Bonneville - (What else?)
Question Neutral indicator light
I just got my bike out of winter storage, and went for a quick blast up the road and back, and noticed my neutral indicator light stayed on through all the gears. It didn't do this when it was put away last fall. Is there an adjustment? Where is it? I also put on a 19 tooth c-shaft sprocket during the winter. There is a difference, but I can't say how much, since I only briefly got up to about 40mph. Pulling away from a stop didn't seem to be a problem, though. I'm not looking to pull wheelies or hole shots, I did enough of that in my younger days.
athomas is offline   Reply With Quote
Old 04-03-2008, 06:28 PM   #2 (permalink)
Favourite Bike: 05 T100
There might be a clue to your problem in this sentence. Did you trap or displace any wires when you re-fitted the sprocket cover after doing this? The switch for the neutral light is not adjustable and lives underneath the engine.
Paul.
Herts. UK
Old 04-03-2008, 11:04 PM   #3 (permalink)
Favourite Bike: my america
trboam's Avatar
Other Motorcycle: moto guzzi 750 ambassador
Unhappy
check to be sure you did not get your neutral light wire caught between the cover and engine case if so the light can stay on and it will also start while in gear , if so your bike can fall over when starting...
personal experience speaking.
stv
TRIUMPH UBER ALLES!!!
trboam is offline   Reply With Quote
Old 04-05-2008, 08:06 PM   #4 (permalink)
Smile Yep, that was it
Thanks guys, that was it. Is it me, or is that a poor design problem? It was actually a little difficult not getting it pinched. I went for a little longer ride this afternoon, to check out the new 19t sprocket. It made the bike a little more relaxed, dare I say, almost Harley-like. Most of the riding I do is on local 2 lanes, where the stock sprocket may be desirable, but when I do ride on the e-way, I felt the rpm were a little too high. A 6 speed would be great. That would give a good low end, with a higher highway gear. I'll have to take a longer ride tomorrow and decide which sprocket I like better.
Old 04-06-2008, 11:13 PM   #5 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
It's you. Be careful.
Marty
Neutral light went out, then.... Riven Twins Technical Talk 11 03-29-2011 12:49 AM
neutral light Zansongs Twins Technical Talk 4 10-01-2007 03:15 PM
No neutral light FlyingScot Twins Technical Talk 1 03-20-2007 12:25 PM
Neutral indicator don't light and starter motor won't crank Les Maintenance & Workshop Talk 4 12-12-2005 12:52 PM
No Neutral Light rdm1 Tiger Workshop (archive) 2 10-27-2005 03:20 PM
