Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShowsBikeBandit
ShopTriumph.com
Old 03-26-2008   #1 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
dang crazy oil leak
I been pulling my hair out looking for a little oil leak that only leaks over 60 mph .I know that sounds crazy but you can wash motor off let it run it wouldnt leak a drop .you can ride it around slow at any rpm you want it wouldnt leak a drop.If you go on the high way and run 2 miles at 60 or above it leaks all over the front of the engine.I was thinking the worst that maybe it was leaking between the jug and the block being as i just put the stroker kit in bike but that wasnt it.The lover o-ring on the oil pipe from the head to the block was where it was.I moved the tube around and put sealer around the hole in the block and that took care of it.Just thought i would post this incase anyone runs in to same crazy thing.I think as wind goes over the hole it makes a vac.sucks the oil out.
Old 03-26-2008   #2 (permalink)
Question Crazy leak
Got the crankcase vented good enuff?? Got that written all over it!! Good luck!!
CAPT D
Old 03-26-2008   #3 (permalink)
Retired Legend
sweatmachine's Avatar
those oil leaks are a mother to chase down. After getting my motor back together I must have had 4 different ones to find. One was just a pinched clutch cover gasket (easy), one was a pinhole-sized void in the sealant for the cases near the alt cover (hard to find, easy to fix), another was the front edge of the cases where there was a bigger void in the sealant. I tried 4 or 5 different sealants and none would work, eventually I just JB Welded the thing. It's only about 1/2" long and hasn't leaked since.
Glad you got yours fixed.
Well, dang... J44Clark Twins Talk 10 01-18-2008 10:46 AM
Oil leak from oil cooler pipe? FlyBri Twins Technical Talk 3 06-21-2007 11:58 AM
Oil leak, right-side oil cover Rincewind Tiger Workshop 2 05-30-2007 10:36 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
