Sounds like it is behaving as it should. 18 tooth sprocket. I checked the plugs after the series of roll-ons and they look a little bit lean. The tan has gone to gray and the base soot is about gone. I think I will ride it awhile normally, i.e. like the old man I am, and check again. If the base soot has not returned I will go to the 130s and see how they do.
A little futzing around with the pilots seemed to make no difference at idle so I need to investigate that also. I have read several times here of others having the same symptom. I will also connect my handy homemade ATF carb balancer.
Just out of paranoia I checked the wheel alignment and sure enough, it was out by nearly an inch!
I might have noticed eventually, if I looked and saw two wheel tracks behind me.
Oops, time to change my sig.
