I've started using 87 octane with no problems so far - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGearHonda PowersportsNew Bonneville
Old 03-22-2008, 08:24 PM   #1 (permalink)
I stopped at a gas station the other day that did not sell mid-grade gas. Only choices were 93 or 87 so just for experimental reasons (and the fact I'm a cheapskate) I filled up the Scrambler with 87. I couldn't notice any difference compared to the 89 I had been using, except my wallet was fuller. I put in another tankful today. I'm listening for pinging but not hearing any. It's not too hot yet, so maybe I'll see problems when the temps rise but life is good so far.
Dale_K is offline   Reply With Quote
Old 03-22-2008, 08:42 PM   #2 (permalink)
better safe than sorry
the scrambler's an awful expensive toy for a self-proclaimed cheapskate to be risking it's health on something like gas. i'm one too, but i allow for the possibility that i'm getting ripped off in the admittedly unlikely event that there really is some kind of a benefit to using high octane... i err on the side of caution.
mine's an '01 bonneville and i feed her nothing but the best gasoline. how much extra can premium vs low grade cost per year of use? $100? i think that's worth the peace of mind. that's just my two cents.
2005 Triumph Bonneville T-100
pretty much stock to the bone, 'cept for some af turn signals... so far.
metasac is offline   Reply With Quote
Old 03-22-2008, 08:56 PM   #3 (permalink)
Favourite Bike: Bonneville
You might not get any warning, but detonation can blow a hole in a piston in nothing flat. I use to top grade because, even though it calls for mid grade, I assume that the pump and hose are full of regular. That could be a significant percentage of a tank full, so by getting premium, I figure that I actually end up with mid grade in the tank.
2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
geolpilot is offline   Reply With Quote
Old 03-22-2008, 09:05 PM   #4 (permalink)
Favourite Bike: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
Midgrade gas is about .01 cent more per gallon around here lets see 3.5 gallons = savings of .035 cents not worth it in my book.
toys for big boys
wildchild is offline   Reply With Quote
Old 03-22-2008, 09:15 PM   #5 (permalink)
357Bob's Avatar
I guess everyone dumped on you didn't they? Well let's dump on them. 93 octane gas is a waste of money. I have never used anything but 87 octane & I just now turned over 14,700 miles in less than 2 years. No knocks. No pings. No nothing. I will admit the money isn't that much but these are the same guys that buy cheap oil filters & go around turning off unused lights. The wrong jets, if too small, will be more likely to cause a ping (and a burned piston) than the cheap gas.
But one word of caution. Don't put in 1 1/2 gals. of diesel. Then it will ping. I barely made it home. But drained it out & put it in the Caprice. She loved it.
If it ain't pinging, don't fix it. Bob.
357Bob
Old 03-22-2008, 10:10 PM   #6 (permalink)
Favourite Bike: Definitely my 2007 Black
Hedge's Avatar
I'm down with Bob! I use 87 octane because I think that all the gas station are full of BS and that they run the same gas out of every nozzle! My bike runs no different with 87 than with 93. I run 87 in my SL500 and my wife's X3 and never have any issues whatsoever. The computers sense the change in octane, if there is any, and self-adjusts. My pop ran 87 in his 740i and it never complained. He just bought a brand new 2008 E350 and runs 87 in that and it runs fine. He runs 87 in my mom's 530i and that runs fine as well. Personally, I think it is all BS until you are running highly modified, high compression engines. Yes - all you 904's Boy's and up should definitely be using high octane, but I think it is a waste for stock low compression motorcycles and stock low compression cars. Just my silly opinion.
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 03-22-2008, 10:38 PM   #7 (permalink)
357Bob's Avatar
Now in my 57 Chevy setting in the garage with a 74 -350 LT1 small block running 11 1/2 TRW pistons with a Lunati cam, holly spreadbore 650, 69-Z manifold, 202-160 valves I must have 93 octane. At 11 MPG (highway) & $3.50 a gallon that is a lot of money. Plus there is antifreeze getting in the oil. So it is parked until better weather to pull it apart.
http://smg.photobucket.com/albums/v1...t=DSCN3153.jpg
Oops. That didn't work.
357Bob
Old 03-22-2008, 10:46 PM   #8 (permalink)
Favourite Bike: 1972 Suzuki TM 250
Loxpump's Avatar
I always heard that you need higher octane gas for higher compression engines, but if you don't need it it's a waste of money. You aren't getting anymore HP by just running higher octane fuel. I still run 93 octane, but maybe I should stop. Around here it is about 20 cents a gallon more.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 03-22-2008, 10:53 PM   #9 (permalink)
357Bob's Avatar
A person probably should be running 89 octane but I just never have. I started out with 87 & have never changed. But 89 would be a good compromise. I guess. Bob.
357Bob
Old 03-22-2008, 10:55 PM   #10 (permalink)
Of course cars have knock sensors, so they can adjust when fed low octane gas, but afaik the twins don't have these sensors. The car suffers lower performance when the knock sensors detect a problem but the bike won't - it'll just knock and hurt stuff. A rider ought to be able to hear it though and so far I don't. It might show up in hotter weather. If it does, I'll go back to 89. I know my previous bike, a Suzuki, had a higher compression ratio and called for only 87. It was water cooled, though.
What got you started? road dog Biker Hang-Out 93 01-20-2009 02:23 PM
Can't get it started. Helmet_Hair Speed Triple Forum 23 05-05-2007 02:35 AM
I've started my own webpage! BIGMICK T3 Sport / Touring Forum 2 10-09-2006 01:31 PM
Bike started right up fuzzdevil Twins Talk 4 08-02-2006 04:47 PM
Getting started mgrocco Classic, Vintage & Veteran 9 04-16-2004 09:39 AM
