What are my carbs trying to tell me? Backfire on startup. - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com
Old 03-22-2008, 08:18 PM   #1 (permalink)
After I put the TORs on I get a backfire everytime I start the bike cold. Choke pulled out all the way, press button, POW, then bike starts. Warm starts are no problem. Didn't do this until the TORs. I put in 115 mains and one shim under the needles. Another observation is that the pilot mixture screws don't respond to changes. I can put the screws pretty much anywhere and the bike runs the same (runs fine at all combinations of load & rpm).
Dale_K is offline   Reply With Quote
Old 03-22-2008, 10:35 PM   #2 (permalink)
Favourite Bike: 2001 BONNIE
BonnieBob's Avatar
Other Motorcycle: I wish, but with a BONNIE
Extra Motorcycle: who needs another
Choke??
Sounds to me like you may not need your choke all the way out, too much gas I think is producing the POW.
As far as you mixture screws go, are you sure you are turning them? They can't work the same everywhere, if they are as you say, then you have some other issue clouding the situation. An issue not related to the TORs, but by circumstance appeared at the same time. My best guess would be cloggish in the carbs.
Good Luck
BB
2001 Red Bonnie, NARK, Nology coils and wires,
Sprints, Corbin gun, IKONs , stainless brake lines, Knee pads, grab rail, chrome chain guard and side stand. Dart fly screen. Kellerman signals, lucas type tail light. G2 a/f analyzer,
BonnieBob is offline   Reply With Quote
Old 03-22-2008, 10:43 PM   #3 (permalink)
Favourite Bike: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
If I touch the throttle mine will back fire
toys for big boys
wildchild is offline   Reply With Quote
Old 03-23-2008, 11:40 AM   #4 (permalink)
Question Backfire
Mine does just the opposite- it will give an occassional pop when its real hot after a ride & I start it up to pull in the garagew/ a little throttle. Never has popped on a cold start!
CAPT D
Old 03-23-2008, 12:38 PM   #5 (permalink)
For curiosity, are there any Scrambler owners here w/out TORs who can say if they get any popping on decel or start-up?
Seems like many w/ the tors on scramblers cant seem to get them dialed in just right
Almost make one wonder how effective they are at times
dave1068 is offline   Reply With Quote
Old 03-23-2008, 09:05 PM   #6 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
check the vac plugs on the intake make sure they dont have a hole in them.
Backfire on startup itcha Twins Technical Talk 4 10-18-2007 10:50 AM
warm engine, major effin backfire on startup - any ideas? metasac Twins Technical Talk 12 10-04-2007 12:19 AM
Backfire by carbs when cold Donkeypunch Twins Technical Talk 6 07-31-2007 08:41 PM
Newbie Question: Backfire on startup with TORs (Scrambler) barfito Twins Technical Talk 10 02-11-2007 09:50 PM
Fan on at startup and always coldnight Sprint Forum 14 05-06-2004 09:05 AM
