Hard Starting after Dominator Installation - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario TourismHonda Powersports
Old 03-21-2008, 08:04 PM   #1 (permalink)
TCL
Favourite Bike: Triumph Bonneville T-100
TCL's Avatar
Other Motorcycle: 1977 Honda CB400F
Question Hard Starting after Dominator Installation
So I installed the Dominator touring pipes about 3 weeks ago and they sound great. My bike also has more midrange power. I am very please except for the fact that the bike does not like to start now. Here is my setup and story:
I have an '07 T100. (Thruxton needles) I live in Florida at sea level. My idle adjustment screw is set at 3 turns out. Originally, I had done the bafflectomy and removed my airbox for K&N's. I moved up to 145 mains and kept the 40 pilots. I drilled my slide to 3mm I installed one shim and the bike dyno'ed perfectly except for a small flat spot around 2000rpms that I was not worried about. I also installed iridium plugs, which I swear allowed me to go higher speeds with lower rpms before I shifted. The bike ran better with every modification.
Once I installed the Dominators, I noticed an immediate power gain. I could run 4th gear up to 70mph before I even thought about shifting into fifth. I had assumed that I would have to go up a main jet size, but I knew I was already jetted too high according to Jenks, so I did not. The only thing I noticed was that I really had to let the bike warm up cold starting and as soon as I put the choke in, the bike wanted to die until I gave it a bit of gas and ran down the street a bit. Because I had extras, I added another shim to make it 1mm total, but I can't really tell a difference.
I figured since Jenks said I was jetted too high, I would go down to 140 mains, but the bike was not as strong and I went back to 145s. I still had problems with cold starting. It has been 75 degrees farenheit. Messing with the idle adjustment screws did not do much, so I left them at 3 turns out and opted to try bigger 42 pilot jets. This was a mistake. I am cold starting worse than ever and the bike seems to be racing at idle, but choking at the same time. If I blip the throttle at lights I stall. I guess it is getting too much gas and choking. My idle used to stay pinned at 1050 in neutral. Now it justs between 900 and 1200rpm in neutral
I am headed to get a dyno next week, but I am curious what others have to say. Since 145 seems like the right main, and 42's are too big for pilots, what can I do to get my bike to start and idle better?
Death or Glory
TCL is offline   Reply With Quote
Old 03-21-2008, 11:12 PM   #2 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
stick with the 42 pilots and try 1 or 1.5 turns out. That's what I had, also at sea level, on my 865 bonnie with pred's and airbox elim.
fwiw, I was running 155 mains and 1 shim.
You are wicked rich with 42s 3 turns out. turn them in and you're golden.
Old 03-22-2008, 10:55 AM   #3 (permalink)
TCL
TCL's Avatar
Thanks, I'll give it a try. Beats taking the carbs apart for the zillionth time.
Death or Glory
Old 03-22-2008, 02:45 PM   #4 (permalink)
Legend
That should get you squared away and running great. You may need to go more/less turns, but that will get you close.
Tune it when the bike is good and warm. The pilot will run different when the bike is hot/cold. If it runs great when cold, but crappy when warm (bogs down) you're too rich. If it's hard to start but runs ok when warm, and takes a long time to get warm you're lean.
Hard starting VTXED Maintenance & Workshop Talk 3 09-30-2007 04:01 PM
Hard starting / starting fluid TailHooker Hinckley Classic Triples 20 09-01-2007 01:39 PM
Hard starting DaveInPortland Twins Technical Talk 18 05-13-2007 08:45 AM
Hard Starting '04 RS troy520 Sprint Forum 9 02-04-2007 12:04 PM
Hard starting. djdankid Sprint Forum 20 09-10-2006 09:47 PM
