Motorcycle.com
Old 03-20-2008   #1 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
Cheap progressive springs fork springs
Ran into a fellow the other day needing to re spring his bonnie and could not afford the emulator straight rate spring option.
So I tried the stock progressives from my v-strom DL-650, and guess what they worked very very well after cutting a set of spacers to set the sag. They seem like a good option for about a 175-225 lb rider. used 5 wt oil and set the oil level at 125mm, may drop it just a tad. Put the tight coils at the top they seem similar in feel to the ikon springs maybe a little firmer sooner in the compression curve but this is good.
DL650 stock springs are avail. on fleabay and the vstrom boards all the time for $10-20.
After 500 mi this is turning out to be a gret option
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 03-25-2008   #2 (permalink)
uzidzit's Avatar
bump
I bumped this so others could see.
Old 03-26-2008   #3 (permalink)
Favorite Bike: Bonneville 2005
chedd's Avatar
Other Motorcycle: Suzuki Dr250
Yeah I put the stock Yamaha Fazer 600 springs I had laying around in my Bonnie with 10W oil and they work great.
2005 Bonnie, grab rail, centre stand,taco, ikons, new front springs, bafflectomy.Metal gear front disk & braded line,K&N,no snork,115s,stock needle.
chedd is offline   Reply With Quote
what do progressive fork springs really do? peter_s Twins Technical Talk 17 08-25-2007 03:16 PM
Progressive Fork Springs wonderdog Twins Technical Talk 2 02-05-2007 09:20 AM
Progressive fork springs Hilts Twins Technical Talk 5 12-07-2006 08:54 PM
Progressive Fork Springs Anchorbend Twins Talk 11 04-03-2006 08:08 AM
Progressive Fork Springs Hinckley Classic Triples 21 01-07-2004 09:27 AM
