Old 03-22-2008   #11 (permalink)
bonnevillebilly's Avatar
Raff
The starter solenoid is located behind the left side cover.
It will have 2 big wires and 2 smaller wires connected to it.
The 2 big wires come directly from the battery and goes directly to the starter.
If you have the ignition on and you jump the 2 big wires that will send
power directly to the starter and turn the starter.
If you hear the same noise and she is not turning the motor
then the starter is not engaging for some season.
It could be the starter if self or it could be in the starter gears inside the
clutch cover. Like Mike mentioned hope it is not the starter gear shaft.
Jump the solenoid and see what happens.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 03-22-2008   #12 (permalink)
Favorite Bike: 03 Bonneville America
Gregger's Avatar
Other Motorcycle: 69 BSA 650
Just make sure you are in neutral since jumpering the solenoid bypasses all the safeties.
Can't wipe this smile off my face!!!!
Gregger is offline   Reply With Quote
Old 03-22-2008   #13 (permalink)
Have you tried bump starting the bike? Coast down a hill with the ignition on (and choke pulled since the bike is cold) and letting out the clutch in 2nd gear. The bike ought to start if the only problem is the starter electrics. If the wheel skids and the motor won't turn, well that would be a bad sign.
Dale_K is offline   Reply With Quote
Old 03-22-2008   #14 (permalink)
And if it doesn't start then push it back up the hill.
357bob
Old 04-04-2008   #15 (permalink)
Push starting didn't work so I had the dealer send a truck. It turns out that the mounts for the shaft that holds the idle gear split on both ends. The bad news is that the entire engine needs to be rebuilt and a computer has to be replaced. The good news is that my warranty is good through July so everything is covered. The not so good news is that it will take a month to fix. I could have been worse.
Thanks for all the suggestions everyone.
raff23 is offline   Reply With Quote
Old 04-04-2008   #16 (permalink)
I'm glad that it worked out for you, meaning still under warranty. This has happened to several people.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 04-04-2008   #17 (permalink)
Gregger's Avatar
And more than several people are beginning to get concerned???
Unlike most other failure modes, how do you prevent this?????
Old 04-04-2008   #18 (permalink)
Favorite Bike: 03 T100 989
mikeinva's Avatar
sorry i was right on this one but glad they will cover it.If the starter motor runs on these bikes its got to be that shaft or the starter clutch on the crank .All the starter is is a motor no drive on it like a car just a gear made on the end of the starter motor shaft.
The drive is the starter clutch on the crank it locks up and turns crank will free wheel turned the other way that shaft that broke holds a idler gear that gears the starter motor to the starter clutch
Old 04-04-2008   #19 (permalink)
Favorite Bike: Black 06 Thruxton
Other Motorcycle: Red 01 SV650S
Case Replacement
That's a few of these incidents isn't it?
Tusitala - Mt Vaea
SHILOH is offline   Reply With Quote
Old 04-05-2008   #20 (permalink)
Post !
Yes,
I've been collecting posts/info about it:
http://www.triumphrat.net/modificati...gs-broken.html
see second page for links to all the posts I've found so far just on the trat.net forums as well as some others have found on other forums.
EDG1911 is offline   Reply With Quote
Stalled & acting strange - help Mancha Twins Technical Talk 3 08-17-2006 08:19 PM
bike stalled and dropped. DrTriumph Sprint Forum 11 07-22-2006 11:15 PM
Speedmaster stalled on 405 this AM? oldsport Twins Talk 1 11-01-2005 10:08 PM
Engine Stalled Speed Triple Forum 8 08-03-2004 05:43 PM
engine stalled between 1 and 2 gear Daytona Deliberations 11 12-31-2003 12:36 PM
