BikeBanditTrident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 03-12-2008   #1 (permalink)
Favorite Bike: Not Sure Anymore
keanhi's Avatar
Help with Speedmaster Front Fork Springs Mod
G'day All,
Not overly impressed with the front suspension, dips down under braking more than I would like and I'm guessing (from what I reading in the threads) that is what progressive front suspension mods are all about.
Now the stock Speedmaster suspension, I have no idea if they use Damper or Cartridge Forks types. The spec sheet I could find only listed them as 41mm front forks.
Saw a thread that had MakDaddy putting in Progressive Rate springs, Thruxton adjustable pre-load caps with Oberon adjuster knobs. Seems like a great option, but where is the best place to purchase this gear/kit...I'm down in Australia but deal with USA companies quite often to get in stuff, so that ain't a problem.
I'm also guessing the 'Progressive Suspension' is the actual company name of one of the brands, but also found 'Ikon' Progressive springs at Newbonneville. Anyone better than the other??
Any opinions or options anyone would like to add, it would be much appreciated.
Cheers.
http://www.newspeedmaster.com/html/i...k_springs.html
http://www.fjmods.btinternet.co.uk/emulators.htm
keanhi is offline   Reply With Quote
Old 03-12-2008   #2 (permalink)
Favorite Bike: 06 Thruxton(black)
cafecruzin's Avatar
Location: land of sweeping plains,drought n flooding rain
try here
http://www.ikonsuspension.com/content/contact.shtml
ROD
As is a tale, so is life: not how long it is, but how good it is, is what matters.
Illegitimis nil carborundum
Quot culi, tot sententiae
cafecruzin is offline   Reply With Quote
Old 03-12-2008   #3 (permalink)
keanhi's Avatar
Originally Posted by cafecruzin View Post
Hi mate,
Thanks for the link...yeah I found them today while surfing...they want AUS$168 for their springs....still not sure about the adjusters, but sure it will get worked out.
Also found this one in Oz for Progressive Suspension.
http://www.zpower.com.au/catalog/pro...ae20a7b19b44d4
Only $149....had the following write up with it;
Progressive Suspension fork springs are progressively wound for a smooth ride and more control under braking. Dual-rate springs have a step in their compression. A 10-20 spring, for example, will require 10 pounds to compress it an inch until the light coils bind, and then 20 pounds per inch. A true progressive spring is wound such that it takes 10 pounds to compress the first inch, then 11 for the next, then 12, and so on, without the sudden crossover from light to heavy that you get in dual-rate springs. Progressive Suspensions spring material is guaranteed for life against sacking or breaking, if they sack more than a quarter of an inch Progressive will replace them.
Old 03-12-2008   #4 (permalink)
Favorite Bike: 05 speedmaster - black
I have the springs from Progressive in my speedmaster, they were a considerable improvement over the stock springs. easy to swap out, a 20 minute job, tops.
mag10 is offline   Reply With Quote
Old 03-12-2008   #5 (permalink)
keanhi's Avatar
Hey mate, you must know what your doing...more than likely take me the weekend If I'm lucky.
Old 03-13-2008   #6 (permalink)
cafecruzin's Avatar
i run ikon front and rear on my Thruxton and am as happy as a pig in poo
with the handling
ROD
Old 03-13-2008   #7 (permalink)
keanhi's Avatar
Hey mate, was thinking of going Ikon...was just going to do the front forks then thought "may as well do the backend"....what was the damage $$ for your rear shockers?
Old 03-13-2008   #8 (permalink)
cafecruzin's Avatar
don't remember exactly... $400+
email Ikon and they will send you a quote
cheers
ROD
Old 03-13-2008   #9 (permalink)
Favorite Bike: 2007 Triumph Speedmaster
erikmustride's Avatar
Other Motorcycle: 1971 Honda CB750 chopper
Extra Motorcycle: 1965 Honda dream 150
I used the progressive rears. $250 I think? Thier website had front lowering springs for $108 if memory serves (which it sometimes does not) So the new springs would be similar in price I believe.
No one hands out medals for "keeping it real"- Torr
When life gives you lemons, you paint that s#*t gold!
erikmustride is offline   Reply With Quote
Old 03-13-2008   #10 (permalink)
Favorite Bike: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
Keep us updated as to what parts and the outcome of putting the parts on Thanks
toys for big boys
wildchild is offline   Reply With Quote
Fork Springs, R Bonnie & Speedmaster the same ? BorgCymru Twins Talk 11 12-06-2007 09:53 AM
1st mod, Race Tech Fork Springs blueagle Sprint Forum 1 03-07-2007 11:54 PM
Front Fork Springs wills Sprint Forum 25 11-22-2006 05:23 AM
Speedmaster front springs Swordymon Twins Technical Talk 19 11-02-2006 01:37 PM
Front fork springs Berkgeorge Twins Talk 10 04-13-2006 10:03 AM
