Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Old 03-03-2008   #1 (permalink)
Favorite Bike: 1964 T120
Other Motorcycle: 2007 Speedmaster
Brakes
05 speedmaster, problems with the front brakes, have replaced rotors just 2 months ago. brakes still feel like the rotors are warped. Any ideas? or some one having the same problem. I like the bike but the front end sucks.
pacfish is offline   Reply With Quote
Old 03-03-2008   #2 (permalink)
Favorite Bike: 2007 Triumph Speedmaster
erikmustride's Avatar
Other Motorcycle: 1971 Honda CB750 chopper
Extra Motorcycle: 1965 Honda dream 150
Any chance the brakes are adjusted to tight? It would cause the wheel to drag.
No one hands out medals for "keeping it real"- Torr
When life gives you lemons, you paint that s#*t gold!
erikmustride is offline   Reply With Quote
Old 03-03-2008   #3 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Maybe the hub is out of round, which may be a warranty issue, or at least a point of negotiation with Triumph. Did the new rotors cure the problem temporarily, then start shaking/vibrating again, or was the problem still there immediately after changing the rotors?
Bob
Old 03-03-2008   #4 (permalink)
PfM
Favorite Bike: 1961 Triumph Thunderbird
PfM's Avatar
Other Motorcycle: 1959 Triumph Tiger 110
Extra Motorcycle: 2006 Scrambler
Ongoing problem; do a search.
On my 4th disc in 16000km.
Cheers
PfM is offline   Reply With Quote
Old 03-04-2008   #5 (permalink)
calif brakes
Brakes never did work right, after the new rotors, worked fine for a short time then back to same.
Old 03-04-2008   #6 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
probably a bad hub
and that is a known warranty repair. Chech the wun out of the mounting surface. I had a warped rotor that was like new and fixed it with a floating rotor from ebc for a honda: here is the post is is a wonderful upgrade, this bike uses a stainless steel rotor from the factory, and stainless rotors are poor in the friction dept.
http://www.triumphrat.net/twins-tech...formation.html
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Brakes? NewOldSkool Twins Technical Talk 6 06-13-2007 12:31 PM
brakes daybird2 Daytona Deliberations 3 06-04-2007 01:14 AM
brakes rosco Classic, Vintage & Veteran 4 05-02-2006 09:55 PM
Brakes? Lono Speed Triple Forum 10 04-20-2006 02:23 PM
Brakes IIMikeForce The Rocket Science Forum 5 07-09-2005 08:52 AM
