BikeBanditMotorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Old 03-01-2008   #1 (permalink)
Favorite Bike: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
Help I think I done screwed up this time
Changing needles in my speedmaster took the top cover off tryed to get at the needle with a needle nose but the pliers I had was to big so I have a little hook so hooked the top of the needle started to pull up and the diaphragm came up so no big deal grap it tip it over got the needle out put the tbs needle and shims in put that side back together went to the other side took the cover off and thought I would just pull on the diaphragm turned it over took out the old needle put in the new one with the shims and now it looks like the rubber diaphragm stretch a bit and don't fit in the groove the way it should any thoughts or will I have to buy new piston/diaphragm thanks
Jerry Education cost money no matter how you get it.
toys for big boys
wildchild is offline   Reply With Quote
Old 03-01-2008   #2 (permalink)
That was the longest sentence I have ever seen. Not sure what you asked. But if the diaphragm can be put back & the top installed I bet it is okay. I pulled the diaphragm completely out then removed the needles. I had some small washers that worked okay for shims then I bought a kit but have never changed out the washers. Also get some of those allen head bolts for your carburators from New Bonneville.They work great.
Good luck. Bob.
357bob
Old 03-01-2008   #3 (permalink)
Retired Legend
sweatmachine's Avatar
just gently press the diaphragm back into the groove, eventually it will fit.
Also, look at your keyboard, 2 keys over from the "M" key there's a little "."
Old 03-01-2008   #4 (permalink)
Favorite Bike: 2001 Sky Blue Bonneville
No worries - leave the diaphragm in it's position overnight, with the cover removed, it'll shrink back given time.
The same thing happened to me, I just left it to the diaphragm fairies and hey presto in the morning they had done their job and I was able to put the cover back on no problem.
Ian
Skyblue62 is offline   Reply With Quote
Old 03-01-2008   #5 (permalink)
wildchild's Avatar
Ok the diaphragm won't stay in the groove. But I will leave it in positoin over night and try agian tomorrow. Maybe the diaphragm fairies will vist me tonight. Thanks all....
Jerry
toys for big boys
Old 03-01-2008   #6 (permalink)
Kframe's Avatar
And once it shrinks back to round, you can use a thin film of grease around the lip to help it stay seated while you screw the cover back on.
-K
Kframe is offline   Reply With Quote
Old 03-01-2008   #7 (permalink)
Newbie
Favorite Bike: 07 Tiger Scorched Yellow
Other Motorcycle: 06 Speedmaster Neon Blue
I’ve heard of people placing the diaphragm in the freezer to shrink and stiffen it. Seeing that you live in Minnesota, getting it cold should not be a problem
MGJohnE is offline   Reply With Quote
Old 03-01-2008   #8 (permalink)
wildchild's Avatar
While I did work on it in an unheated garage temp outside was about 32 degrees. I would say not much warmer in the garage. Think that would make a difference.
toys for big boys
Old 03-01-2008   #9 (permalink)
Favorite Bike: Triumph Thruxville :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Extra Motorcycle: TR1 Chop/Bobber
There a right bstrd to get back in the slot sometimes. Its the concave affect of the diaphragm. best way I found was to fill the grove up with petroleum jelly and press the edging in. The jelly holds it in place. Work it around slowly keeping your other 7 hands free to hold it in.
You'll get what I mean
It will fit.
BorgCymru is offline   Reply With Quote
Old 03-02-2008   #10 (permalink)
wildchild's Avatar
I would like to take this time to thank you people for your help. Got the diaphragm back in place.
Jerry
toys for big boys
Uh oh....I might have screwed up.... GrayMitchell Classic, Vintage & Veteran 14 06-30-2007 04:04 PM
I'm screwed....need help dazco Modifications & Workshop Talk 10 11-07-2006 05:59 PM
I'm screwed....need help dazco Twins Talk 70 11-06-2006 09:17 AM
i screwed up again... tekmoe Speed Triple Forum 10 05-18-2006 07:57 AM
I think I got screwed dardoonk Twins Talk 11 11-24-2005 11:44 PM
