Key Relocation Kit - Page 10 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-10-2011, 03:35 PM   #91 (permalink)
Legend
DEcosse's Avatar
But then you would have to take your gloves off!
For anyone who wants to see the Keyless demo, I posted up in the S3 forum.
http://www.triumphrat.net/speed-trip...-ignition.html
Old 02-04-2011, 03:01 PM   #92 (permalink)
Legend
DEcosse's Avatar
I've now made a completely hands-free system - http://www.triumphrat.net/speed-trip...part-deux.html
Now, whenever you approach the bike, it is enabled for ignition (set by the clutch switch).
Works within about 5' range (you can adjust the range by playing with antenna lengths)
Just keep remote in pocket and it disarms as you approach and re-arms when you walk away from the bike.
It's same interface for most Triumphs - the key-switch connectors are common throughout most of range, as is the Triumph/Datatool alarm connector.
The only invasive connection required is to the clutch switch (or side-stand switch, whatever your preference)
Old 09-28-2011, 04:05 PM   #93 (permalink)
Newbie
Main Motorcycle: Thruxton 08
Extra Motorcycle: CL350 72
Originally Posted by thruxton09 View Post
AAArgh Just had a look at my 09 thruxton, like oldefart says doesnt work on the later models. Guess I'll stick with the original key location for a while.
I just want to add that recently experienced this myself after removing the headlight bracket on my 08 Thruxton. The tank is just a little too much in the way... I just ordered the Joker Machine Relo bracket from BC.
S
botdeluxe is offline   Reply With Quote
Old 09-28-2011, 06:10 PM   #94 (permalink)
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
Originally Posted by ivar View Post
My main grief was that I wanted to be able to reach the key while still having the clutch engaged.
Mine too Ivar.
I did the headlight bracket flip and 10 minutes later - all done.. Easy mod and I am well pleased.
I looked at D9's ignition relocation to the stem but it was just not in my budget. Seth was very helpful and fast with the information I must add.
Thanks for the update DeCosse. I am always impressed at your posts
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 10-26-2012, 03:53 PM   #95 (permalink)
Main Motorcycle: 2010 T100 Black / White
Originally Posted by DEcosse View Post
How about 'keyless'?
RFID is pretty easy install!
Be happy to provide 'how to' if anyone interested
Pretty low cost - RFID Tag Reader and a couple of relays.
Under $25 total
I was looking at doing that but kits sell for $300! Can you post a how to? I would love to do that. I saw one that had a glass tube that could be sewn into the glove. How cool is that?
fernandos1 is offline   Reply With Quote
Old 10-26-2012, 06:51 PM   #96 (permalink)
R0B
Main Motorcycle: 2004 790 Bonnie
Other Motorcycle: scrambler with sidecar
Extra Motorcycle: BMW R1150RT
I saw these after reading on here............
http://www.ebay.co.uk/itm/UNI-RFID-P...item2a1d8c3b30
http://www.digitalguarddawg.com/mm5/...egory_Code=KEY
As an electronics idiot it's more expensive, but I might be able to install it and it would work afterwards.
Rob
R0B is offline   Reply With Quote
Old 10-27-2012, 03:38 PM   #97 (permalink)
Legend
DEcosse's Avatar
Originally Posted by fernandos1 View Post
...Can you post a how to? I would love to do that. I saw one that had a glass tube that could be sewn into the glove. How cool is that?
There are different kind of TAGs available, including the small glass ampoule that can be put in a glove - or for the brave, implanted in your skin! (not for me!!!!)
All are programmable into the low-cost EBay RFID receiver that is linked in my post above.
I liked the watch-band style personally -
http://www.trossenrobotics.com/store...tch-Style.aspx
or
http://www.phidgets.com/products.php?product_id=3905_0
or the ampoule - http://www.trossenrobotics.com/store...poule-Tag.aspx
you can also even get real watches from EBay in Germany
The circuit posted in post # 87 is essentially the 'how to':
All you need is the RFID kit, three relays and a couple of diodes from RadioShack
But in fact if eliminating the key completely you can get it down to 2 relays since you no longer have a key-position parking light.
That revision is linked below.
You need to consider placement of the RFID controller and antenna - the antenna will read through plastic, not through metal!
And tag needs to be within about 2" so think about placement and test before you decide on final location.
The power relays should fit inside the headlight shell and is ideal location to connect onto the original main harness connector;
you can also pick up the Kill & clutch signals inside here also.
The easiest thing is to actually use your key-switch harness and connector if you don't mind cannibalizing it;
If you refer to the diagram above, using the wire colours on the key-switch harness: (EFI switch in parentheses)
1) Delete the third relay
2) For first relay connect Red/Yellow (or White) to 30 and Green (or Brown) to 87
3) For second relay, connect Red/White (or White/Green) to 30 and Orange (or White/Black) to 87
4) Connect the Brown (Red) & Gray (Blue) together.
Then tap onto the Green/Brown wire from the Main Harness side of right bar switch - PosiTap connector is ideal - and feed this via the diode to 86 of Relay 1. This is the output from Kill Switch and is used to set & drop the relay latch.
Also tap onto the Black/Pink (Black/Orange) wire of the Main Harness side of Left Bar Switch Connector - this is clutch switch and used to power the ground side of the RFID module.
(If not EFI, note that side-stand will also required to be in raised position to enable power)
The RFID power and output are connected as shown - best to use a diode to isolate that signal also.
If using diode (or resistor) suppressed relays, the diodes across each relay coil may be eliminated - otherwise is good practice to add these.
To operate, you pull clutch lever to power up the RFID (note that on carb bikes, the side-stand will also have to be raised first);
then swipe the tag;
If the Kill switch is set to Run, the ignition will latch on.
When Kill is set to Kill, it will drop the latch. (and require a subsequent swipe of tag to re-enable)
This is what it looks like with above revisions:
Old 11-30-2012, 07:54 PM   #98 (permalink)
Main Motorcycle: Cruiser/Classic
Ocka's Avatar
Thumbs up Sorry for rezzing but this was awesome
Originally Posted by sweatmachine View Post
check out thrux351's 'free' key location mod, the holes are already on the frame (go look!) and all you need is 2x self-tapping sheetmetal screws and 2x 1/4" spacers to go behind the ignition to allow for the wires. I plan on doing this to mine:
Sorry for bringing this back, but I found those holes and I prefer the ignition here than on the ears! Got all the stuff from OSH for around $5 more or less.
Ocka is offline   Reply With Quote
Old 12-02-2012, 09:26 PM   #99 (permalink)
Legend
DEcosse's Avatar
The problem I personally have with that ^^^ mod is that it takes seconds to remove the switch and hot-wire it.
But no worse than someone jamming a screwdriver in it I suppose if they really want it.
Key Relocation Bugsy-12GSRC Twins Technical Talk 7 07-05-2007 09:59 PM
Sprint ST seat key relocation blurb Suncoast Sprint Forum 4 12-09-2006 11:45 AM
Ignition Relocation Kit Mounted on Right? Ramjet Twins Technical Talk 1 08-15-2006 07:25 AM
key relocation skeeterbarnes Twins Talk 2 07-05-2006 09:36 PM
Footrest Relocation Kit Jamie The Rocket Science Forum 9 08-24-2005 09:20 PM
